Ask a Question
There are no questions. Be the first to ask a question!
Background
The Z323 Rich 360* Sound is a compact 2.1 desktop speaker system sold under the Logitech Z-series line. It combines two satellite speakers with a powered subwoofer to deliver fuller low-end than basic stereo speakers. The system uses durable ABS plastic enclosures and cloth speaker grilles for everyday desktop use, with a wired control pod for quick adjustments. Key features include a dedicated subwoofer, two satellite drivers, and simple analog connectivity for PCs and other audio sources.
Identification
The Logitech Z323 Rich 360* Sound can be identified by the model number (M/N S-00075A). The model label is on the product label (usually on the subwoofer chassis or underside). This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Manufacturer: Logitech
  • Model Number: Z323 (often listed as Logitech Z-323 or Z323 Rich 360 Sound)
  • Form Factor: 2.1 desktop speaker system (two satellites + powered subwoofer)
  • Connectivity: Analog stereo input (3.5 mm TRS) — standard aux connection for PCs and portable audio devices (specific cable types and any adapters not listed on product page)
  • Power: AC mains powered powered subwoofer with internal amplifier (exact adaptor/transformer specs not specified on product page)
  • Control: Wired control pod for power and volume (control pod integrated inline between source and speakers on many Z-series models; exact button/layout not specified)
  • Components: 2 satellite speakers, 1 powered subwoofer, wired control pod/cable
  • Driver Details: Satellite and subwoofer driver sizes and manufacturers are not specified on the scraped product page
  • Frequency Response / Power Ratings: Not specified on the scraped product page — refer to original packaging or manual for RMS/peak power and frequency response
  • Dimensions & Weight: Not specified on the scraped product page; dimensions vary by satellite and subwoofer unit
Troubleshooting
Common repair-relevant faults include no audio (often caused by loose/failed audio cables or a faulty control pod), intermittent sound or distortion (damaged speaker drivers or amplifier issues), and complete power failure (faulty power input or internal fuse). Diagnose by verifying cables and source, testing with a known-good audio source, checking the inline control pod and power connector, and using a multimeter to test continuity on power leads and speaker wiring.
For additional troubleshooting help, visit: Visit Logitech Support (https://support.logi.com) for product help, downloads, and contact options. The Amazon product listing may also include retailer support details.
Additional Information
Warranty Info
Warranty varies by region; Logitech commonly provided a limited hardware warranty (typically one year) — check Logitech support or your retailer for the exact warranty period and coverage.
Tim Asp
42,386 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 61
All Time: 518
