Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Wireless Keyboard K350 is an ergonomic, full-size wireless keyboard designed for comfortable long typing sessions, recognizable by its wave-shaped key layout and cushioned palm rest. It is built from durable ABS plastic with a coated finish and a spill-resistant design intended to withstand daily office use. Key features include an ergonomic wave contour, full numeric keypad, multimedia hotkeys, and a compact 2.4 GHz USB receiver for wireless connectivity. The K350 uses long-life battery design and simple plug-and-forget wireless pairing for reliability.
Identification
The Logitech WIRELESS KEYBOARD K350 includes Keyboard (M/N Y-R0053) and USB receiver (M/N C-U0007). Model labels are located as follows — Keyboard: on the underside product label; USB Receiver: printed on the flat face or side of the receiver housing near the USB plug. Each component carries its own model (M/N) and serial (S/N) identifiers.
Specifications
  • Form Factor: Full-size, wave ergonomic layout with integrated cushioned palm rest
  • Switch Type: Rubber dome membrane (Logitech proprietary membrane key switches)
  • Connectivity: 2.4 GHz wireless via USB nano receiver (plug-and-forget) — may be Unifying-compatible on some revisions
  • Receiver Model(s): Varies by production run; typically a Logitech nano USB receiver (model information printed on the receiver housing; not all units are Unifying-receiver variants)
  • Power: 2 × AA batteries (user-replaceable); rated for extended battery life (multi-year typical, varies with usage)
  • Backlighting: None (no backlit keys)
  • Hotkeys / Controls: Multimedia and hotkeys (volume, media playback, and shortcut keys); F-key functions vary by OS and driver support
  • Materials: Durable ABS plastic housing with coated finish and spill-resistant key well; foam-cushioned palm rest
  • Range: Typical wireless range up to ~10 meters (line-of-sight) depending on environment
  • Compatibility: Windows and macOS compatible for basic typing and media keys; advanced settings may require Logitech software (Logi Options+) where supported
Troubleshooting
Common repair-relevant faults include unresponsive keys (often caused by debris or degraded rubber domes) and connectivity/pairing failures. Diagnose by swapping batteries, testing the receiver in multiple USB ports, re-pairing or replacing the nano receiver, and using a key tester to isolate failed keys; opening the case allows inspection of the membrane and PCB for corrosion or physical damage.
For additional troubleshooting help, visit: Visit https://support.logi.com and search for Wireless Keyboard K350 for product support, drivers, and contact options.
Additional Information
Warranty Info
Typically covered by Logitech limited hardware warranty (region dependent); consult Logitech support for specific warranty duration and claim procedures.
Logitech Wireless Wave Combo MK550 Getting Started (EN, FR)
Logitech Wireless Keyboard K350 User Guide
Logitech Wireless Keyboard K350 User's Guide (EN, SV, DA, NO, FI)
Logitech Wireless Keyboard K350 User's Guide (EN, DE, FR, IT)
Logitech Wireless Keyboard K350 User's Guide (EN, ES, FR, PT)
Logitech Wireless Keyboard K350 User's Guide (EN, IT, ES, PT, EL)
Logitech® Wireless Keyboard K350 User's Guide (EN, FR, NL, EL, TR, AR)
Logitech Product Catalog 2010–11, Volume 3
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 72
All Time: 451
