Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The USB Headset Mono H570e is a single-ear, wired USB headset designed for office and call-center use, offering hands-free communication and a noise-canceling microphone for clearer calls. It is built from durable plastics with reinforced headband components to withstand daily wear in professional environments. Key features include a boom microphone, plug-and-play USB connectivity, and an over-the-head design for extended comfort. Logitech's support materials emphasize basic, driverless compatibility across common desktop operating systems.
Identification
The Logitech USB Headset Mono H570e can be identified by the model number (M/N A00193). The model label is on product packaging and on the headset housing. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Model Number: H570e
  • Form Factor: Mono (single-ear) over-the-head wired headset
  • Connectivity: USB-A (fixed cable, plug-and-play)
  • Microphone: Boom-mounted noise-canceling unidirectional microphone (exact capsule model not specified by support page)
  • Materials: Durable ABS plastic housing with reinforced headband components (metal reinforcement reported in product design)
  • Compatibility: Windows and macOS — basic audio and microphone functions are driverless according to Logitech support
  • Cable: Fixed USB-A cable (length not specified on the official support page)
  • Key Switch Manufacturer: N/A — no mechanical key switches present
  • Spare Part Model Numbers: No spare-part numbers listed on the Logitech support article; support page indicates no spare parts are available
  • Firmware / Software: No firmware updates or specialized software required; Logitech recommends Logi Options+ for compatible devices but none is required for H570e basic operation
Troubleshooting
Common repair-relevant faults include intermittent or failed audio/microphone due to cable damage, failed USB connector, or detached internal wiring. Diagnose by testing the headset on multiple USB ports/computers, visually inspecting the USB cable and strain-relief, and opening the earcup to check solder joints and wire continuity with a multimeter. Replace damaged cable/connector or re-solder broken wiring as needed.
For additional troubleshooting help, visit: Refer to Logitech Support (https://support.logi.com) for assistance; the product support article for the H570e contains FAQ and contact options.
Additional Information
Warranty Info
Refer to Logitech's regional warranty information available on their support site; warranty coverage varies by region and purchase channel.
Logitech H570e USB Headset Mono and Stereo Setup Guide (EN, FR)
Logitech USB Headset H570e Mono- und Stereo-Ausführung Produktübersicht
Гарнитура Logitech USB Headset H570e, моно и стерео — техническое описание
Logitech USB Headset H570e Mono and Stereo Setup Guide (EN, FR)
Logitech H570e USB-A Headset Data Sheet
Logitech USB Headset H570e mit USB-A-Kabel – Datenblatt
Logitech USB-headset H570e Datasheet
Logitech USB Headset H570e Stereo Data Sheet
Logitech USB Headset H570e Corded Mono and Stereo Data Sheet
Logitech H570e USB Headset Data Sheet
Logitech H570e USB Mono/Stereo Headset Setup Guide (EN, DE, FR, IT, ES, PT, NL, SV, DA, NO, FI, EL, RU, HU, CS, PL)
Logitech USB Headset H570e Data Sheet, Mono and Stereo Versions
Logitech USB Headset H570e estéreo — Ficha técnica
Logitech USB Headset H570e com cabo USB-A — Ficha técnica
Logitech USB Headset H570e Setup Guide
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 42
All Time: 220
