Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background
The Logitech Litra Beam is a compact, high‑quality LED streaming light aimed at content creators, streamers, and remote workers. It provides adjustable color temperature and brightness with a soft, directional diffusion designed to produce flattering, even illumination. The unit is constructed from durable materials — an aluminum heat sink/housing combined with reinforced polycarbonate and a durable clip/mount — to withstand repeated attachment and positioning. Key features include USB‑C power, in‑line brightness/color controls and compatibility with Logitech software for basic tuning.
Identification
The Logitech LITRA BEAM can be identified by the model number (M/N VR0031). The model label is on the rear of the housing or on the supplied USB‑C cable/packaging. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
- Form Factor: Clip‑on rectangular LED light for desktop/monitor mounting
- Light Source: High‑efficiency LED array (integrated) with diffused optics
- Color Temperature Range: 2700 K – 6500 K (adjustable) — not specified in FAQ but reported on product materials
- Brightness Control: Continuously adjustable (0–100%) via onboard controls and Logitech software (Logi Tune/Options+) (control method varies by platform)
- Color Rendering Index (CRI): Typically ≥90 (claimed on product materials; not listed in FAQ)
- Connectivity / Power: USB‑C power input (5 V via USB‑C cable; power adapter not included) — powered only, no data connection required for basic operation
- Mounting: Integrated spring clip plus ball‑joint swivel for multi‑angle positioning; compatible with standard 1/4" tripod mounts on some models (check product variant)
- Materials: Aluminum housing/heat sink with polycarbonate diffuser and reinforced clip components
- Dimensions & Weight: Not specified in the provided support article (see official product page for exact dimensions)
- Model / Regulatory Numbers: No spare part or model numbers listed in the provided Logitech support FAQ; check product packaging or underside regulatory label for M/N on your unit
Troubleshooting
Common repair‑relevant faults include failure to power on, intermittent flicker, dim LEDs, or broken/loose clip/mount. Diagnose by testing with a known‑good USB‑C cable and power source, inspecting the USB‑C port and cable for physical damage, and confirming operation on another host; verify mounting hardware and the clip for mechanical failure. If LEDs remain dim or flicker after swapping cables and power, internal LED driver or solder joint failure is likely and may require board‑level repair or replacement.
For additional troubleshooting help, visit: Visit Logitech Support (https://support.logi.com) for product assistance, diagnostics, and contact options. Use the Litra Beam FAQ and contact form for region‑specific help.
Additional Information
Warranty Info
Refer to Logitech warranty information for your region; most regions offer a limited hardware warranty (commonly 1 year). Check the product registration and warranty pages on Logitech.com for specifics.
