Ask a Question
There are no questions. Be the first to ask a question!
Background
The Logitech G PRO Mechanical Gaming Keyboard is a tenkeyless mechanical keyboard designed for esports and competitive gaming, offering a compact layout and pro-grade performance. It features per-key RGB LIGHTSYNC illumination, onboard profile storage, and tournament-style detachable cable for portability. The keyboard is built from durable materials including a reinforced internal plate and rugged ABS plastic keycaps to withstand heavy use. Key features include high polling rate, low-latency USB connectivity, and Logitech's Romer-G mechanical switches.
Identification
The Logitech G PRO Mechanical Gaming Keyboard can be identified by the model number (M/N YU0039). The model label is on the underside of the keyboard. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Tenkeyless (87-key / TKL)
  • Switch Type: Romer-G mechanical switches (designed by Logitech; manufactured by Omron). Available in tactile and linear variants on different SKUs.
  • Connectivity: Wired USB (detachable braided micro-USB cable)
  • Polling Rate: 1000 Hz (1 ms)
  • Backlighting: Per-key RGB LIGHTSYNC programmable lighting
  • Onboard Memory: Onboard memory for storing multiple profiles (commonly up to 3 profiles)
  • Rollover / Anti-ghosting: N-key rollover / anti-ghosting over USB
  • Keycaps: OEM-profile ABS keycaps (removable)
  • Power: USB bus-powered
  • Compatibility: Windows and macOS (configuration via Logitech software: Logitech G HUB / support.logi.com)
Troubleshooting
Common repair-relevant faults include unresponsive or double-typing keys (often due to switch failure, debris, or solder joint issues), non-functional backlighting (faulty LEDs or connector/cable problems), and USB connectivity failures (cable or connector damage). Diagnose by removing keycaps and testing individual switches, swapping the detachable cable or USB port, checking firmware/software, and inspecting the PCB and switch solder joints for broken traces or cold joints with a multimeter.
For additional troubleshooting help, visit: Visit support.logi.com for drivers, Logitech G HUB software, firmware updates, and contact options.
Additional Information
Warranty Info
Limited hardware warranty (typically 1–2 years depending on region and retailer). See Logitech support for specific regional warranty terms.
Tim Asp
42,386 Reputation
9 Guides authored
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 144
All Time: 767
