Ask a Question
There are no questions. Be the first to ask a question!
Background
The G502 X PLUS Millennium Falcon Edition is a premium gaming mouse from Logitech G featuring themed artwork and premium construction. It uses durable materials and reinforced housing designed for extended gaming use, and offers LIGHTSPEED wireless performance with low-latency connectivity. Key features include a high-precision HERO sensor, programmable buttons, adjustable DPI, and a rechargeable battery with USB-C charging. The Millennium Falcon Edition applies special cosmetic finishes while retaining the same internal hardware as the G502 X Plus line.
Identification
The Logitech G502 X PLUS MILLENNIUM FALCON can be identified by the model number (M/N CU0021). The model label is on retail/packaging; the model label and regulatory markings are located on the underside of the mouse. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Manufacturer: Logitech (Logitech G)
  • Model: G502 X PLUS Millennium Falcon Edition
  • Sensor: HERO 25K optical sensor (up to 25,600 DPI)
  • Switches: Logitech proprietary mechanical/optical primary button switches (Logitech G-branded; OEM not publicly specified)
  • Connectivity: LIGHTSPEED Wireless (2.4 GHz) and wired USB-C
  • Report Rate: Up to 1000 Hz (WIRELESS via LIGHTSPEED)
  • Battery & Charging: Rechargeable internal Li-ion battery, USB-C charging (capacity not specified by Logitech)
  • Buttons: Programmable buttons including left/right primary, scroll-click, DPI shift, and additional side buttons (total varies by region/config)
  • Weight: Lightweight gaming mouse design; exact weight depends on configuration (Logitech specification for G502 X Plus line)
  • Software/Firmware: Managed via Logi Options+ (Logitech recommended); firmware updates available through Logitech support
Troubleshooting
Common repair-relevant faults include primary button double-clicking (worn switches), intermittent wireless drops, and scroll-wheel encoder failures; diagnose by testing with the USB-C cable (wired mode), swapping the LIGHTSPEED receiver and USB port, checking firmware via Logi Options+, and isolating the fault to the switch/encoder by observing behavior in wired mode.
For additional troubleshooting help, visit: Visit https://support.logi.com for product setup guides, software (Logi Options+), and support articles.
Additional Information
Warranty Info
Limited hardware warranty varies by region (commonly 2 years); check Logitech warranty terms on their support site.
Tim Asp
42,365 Reputation
9 Guides authored
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 97
All Time: 696
