Ask a Question
There are no questions. Be the first to ask a question!
Background
The Flight Throttle Quadrant is a desktop flight-simulator control module designed for tactile, manual control of throttle, propeller and mixture (or multiple engine throttles) in flight-sim setups. It is built from durable materials — high-strength ABS plastic housing with metal lever arms and a steel mounting/bracket interface — for high-cycle mechanical durability in repeated use. Key features include three full-range analog levers, a stable weighted base with rubber feet, programmable switches on the base, and standard USB-HID connectivity for plug-and-play operation. Logitech's support notes that downloads and legacy software for some older devices are no longer maintained, so it uses standard OS HID drivers for basic functionality.
Identification
The Logitech FLIGHT THROTTLE QUADRAN can be identified by the model number (M/N JU0026). The model label is on the FLIGHT THROTTLE QUADRAN can be identified by its three-lever quadrant layout with Logitech/Saitek branding and a model/serial label on the underside of the base. Controls and user-accessible switches are on the top face of the unit; the USB cable exits the rear. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Desktop throttle quadrant with three full-length levers
  • Axes: 3 analog axes (throttle / propeller / mixture or multi-engine throttle mapping) via linear rotary sensors
  • Connectivity: Wired USB (USB-A plug), bus-powered; enumerates as standard USB HID game controller
  • Sensors: Linear rotary potentiometers (manufacturer not specified by Logitech on support page)
  • Switches: Multiple programmable push and rocker switches on base (exact counts not published in Logitech support article)
  • Materials: High-strength ABS plastic housing, die-cast / steel lever arms and metal mounting bracket; rubber anti-slip feet
  • Mounting: Screw-through mounting provisions and clamp-ready front lip for desk attachment
  • Compatibility: Windows and macOS via USB HID; legacy Logitech/Saitek software is no longer maintained per support notice
  • Power: USB bus-powered (no external adapter)
  • Interface: Standard HID joystick/flight-controller profile (no proprietary receiver)
Troubleshooting
Common repair-relevant faults include worn or noisy potentiometers causing axis jitter or dead zones, sticky or misaligned levers from dirt or worn bushings, and USB connectivity issues. Diagnose by verifying USB enumeration and axis movement in OS/Game controller properties, recalibrating in software, listening/feeling for mechanical binding, and testing potentiometers with a multimeter for smooth resistance change.
For additional troubleshooting help, visit: Visit Logitech Support (support.logi.com) for product registration, warranty claims, and assistance; legacy downloads for some devices may no longer be available.
Additional Information
Warranty Info
Refer to Logitech's regional warranty policies (file a warranty claim via support.logi.com). Warranty period varies by region and purchase date.
Tim Asp
42,436 Reputation
9 Guides authored
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 45
All Time: 374
