Shop the Holiday Gift Guide
No Image
This wiki is missing a device image. Help improve this page by uploading one!
16 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
ES4100
Background
The Lifan Generator ES4100 is a portable, gasoline-fueled electrical generator. Its intended use includes supplying emergency electrical power for areas like construction sites, open-air events, recreational vehicles, and as a backup power source for homes.
The generator is powered by a 420cc OHV 4-stroke, air-cooled gasoline engine and can deliver up to 4,000 watts at peak and 3,500 watts at a rated output. It provides 120V or 120V/240V power, making it capable of running various tools, appliances, and systems. The fuel tank can hold 6.6 gallons of gasoline, allowing it to run up to 12 hours at 50% load. The generator is also designed to produce less noise compared to other generators, with a noise level of less than 69 dB(A) at no load. It measures 27.5" x 27" x 26" and weighs 197 lbs without fuel.
The Lifan Generator ES4100 comes with a 4-in-1 digital meter for voltage, frequency, an hour meter, and oil warning. It is equipped with a low oil shut-off feature to prevent engine damage and overload protection with auto idle control. The generator also has an automatic voltage regulation to deliver steady power and a brushless alternator for durability. It also features an electric start with recoil backup. The generator's frame is made of steel, with lifting eyelets and wheels designed to never go flat, promoting portability.
Technical Specifications
  • Engine: Lifan 420cc OHV 4-stroke air-cooled gasoline engine
  • Output power: 4,000 watts peak / 3,500 watts rated
  • Output voltage: 120V / 240V
  • Outlets: Two 120V 20A outlets, one 120V/240V 30A locking outlet
  • Fuel tank capacity: 6.6 gallons
  • Run time per tank: Up to 12 hours at 50% load
  • Noise level: Less than 69 dB(A) at no load
  • Dimensions: 27.5" x 27" x 26"
  • Dry weight: 197 lbs
  • Additional features: 4-in-1 digital meter for voltage, frequency, hour meter, and oil warning; Low oil shut off; Overload protection with auto idle control; Automatic voltage regulation; Brushless alternator; Electric start with recoil backup
  • Physical characteristics: Steel frame with lifting eyelets and never-flat wheels for portability.
Warranty
The Lifan Generator ES4100 comes with a 2-year limited warranty provided by Lifan Power USA Corp. This warranty covers any manufacturing defects or faults that may occur during the warranty period under normal usage conditions. To claim the warranty, it would likely involve contacting Lifan Power USA Corp directly with your proof of purchase, details of the defect, and the product's model number. However, the specific instructions and conditions for claiming the warranty are not mentioned in the context provided. It is advisable to consult the product manual or official website for precise warranty claim procedures.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 46
All Time: 548
