21 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
ES3500E
Background
The Lifan Generator ES3500E is a generator produced by Lifan Power USA. This generator is powered by a 389cc Lifan OHV 4-stroke engine and offers 3500 starting watts and 3000 running watts of power. Its fuel source is unleaded gasoline with a fuel tank that can hold up to 4 gallons. At half load, it can operate continuously for up to 8 hours. This generator features two 120V 20A outlets and one 120V 30A twistlock outlet. It measures 24.8 x 17.7 x 22 inches and weighs 99 lbs.
This generator is designed for a variety of uses such as construction, emergency backup power, and recreational activities. It includes an electric start and a metal cage frame with noise damping features. The engine can deliver reliable power under heavy loads and has a low oil shut off protection to prevent damage if the oil level is low. The ES3500E can produce clean power, making it suitable for sensitive electronic devices and appliances. It comes with Overload Protection (OLP) to shut down automatically when the power capacity is exceeded, and features such as an easily accessible fuel cap, a folding handle, and flat-free wheels for ease of movement.
Technical Specifications
- Model Number: ES3500E
- Product Type: Generator
- Engine: 389cc 4-stroke
- Fuel: Unleaded gasoline
- Fuel Tank Capacity: 4 gallons
- Runtime: Up to 8 hours at 50% load
- Output: 3500 starting watts / 3000 running watts
- Outlets: Two 120V 20A outlets, one 120V 30A twistlock outlet
- Dimensions: 24.8 x 17.7 x 22 inches
- Weight: 99 lbs
- Additional Features: Electric start, metal cage frame with noise damping, low oil shut off protection, easy access fuel cap, folding handle, flat-free wheels, Overload Protection (OLP)
Warranty
The Lifan Generator ES3500E comes with a 2 year limited warranty. This warranty covers any defects in materials and workmanship. Keep in mind that this warranty is only valid for private, personal use and requires proof of purchase. For commercial and rental use, the warranty is shorter, lasting only 90 days. To claim the warranty, you would typically need to provide your proof of purchase and get in touch with Lifan Power USA or the retailer you purchased from.
Lifan Energy Storm ES3500–ES8000 Generator Operating Instructions and Owner's Manual
