6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
G 4000 OH
Background
The Karcher G 4000 OH is a gas-powered pressure washer, released in 2010 by the German manufacturer, Kärcher. This machine is designed to handle heavy-duty outdoor cleaning tasks. The specifications of the washer include a 390 cc engine with an output of 5.7 HP, a water pressure capacity of up to 4000 PSI, and a flow rate of 4 gallons per minute. It operates on unleaded gasoline and has a 1-gallon detergent tank. The washer weighs 177 lbs and has a 50 ft high pressure hose.
The G 4000 OH includes several features that support effective and efficient cleaning. It includes a patented water-cooled motor pump that uses the water flow through the pump to cool down the motor, which aids in extending its lifespan. It comes with a two-wand system, a variable pressure wand for adjusting the water pressure, and a rotary wash wand with a spinning nozzle head for a wider cleaning path. The device also has an integrated hose reel and a detergent injection system that automatically mixes the detergent with water. It is equipped with metal wheels and a handle for easy movement around outdoor areas. The Karcher G 4000 OH can be utilized for a range of heavy-duty cleaning tasks such as stripping paint from exterior walls, cleaning concrete surfaces, washing vehicles and equipment, and removing stubborn dirt. It finds usage in industries such as construction, agriculture, transportation, and mining, along with professional cleaning companies.
Technical Specifications
- Model Number: G 4000 OH
- Product Type: Pressure Washer
- Engine: OHVI 390 cc engine
- Power Output: 5.7 HP
- Fuel Type: Unleaded gasoline
- Pump: Triplex plunger pump
- Water Pressure: Up to 4000 PSI
- Water Flow Rate: 4 gpm
- High Pressure Hose Length: 50 ft
- Detergent Tank Capacity: 1 gallon
- Weight: 177 lbs
Warranty
The Karcher G 4000 OH pressure washer comes with a warranty of 2 years provided by the manufacturer, Karcher. This warranty period begins from the date of purchase and covers defects in materials or workmanship under normal use and maintenance. It is important to note that in order to claim the warranty, proper care and maintenance of the product is required. However, the specific terms and conditions of the warranty, including what is excluded or how to specifically claim it are not mentioned in the document. For detailed information, it is advisable to refer to the warranty card or contact Karcher's customer service.
