No Image
This wiki is missing a device image. Help improve this page by uploading one!
6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
G2000MK
Background
The Karcher G2000MK is a gas-powered pressure washer. It was introduced in 2010 and is intended for residential use. The pressure washer is powered by an 87cc Karcher GC series engine and can generate a pressure of 2000 PSI, with a water flow rate of 2.0 GPM. It has a power rating of 1.7 kW and can hold up to 0.95 gallons of fuel. The dimensions of the pressure washer are 16 x 19.9 x 23 inches and it weighs 54.8 lbs.
The G2000MK is capable of generating 40 times more pressure than a typical garden hose, making it suitable for heavy-duty cleaning tasks such as stripping paint, cleaning concrete, or removing oil stains. Despite its capacity, the unit is relatively lighter than most gas-powered pressure washers due to its compact size. The pressure washer features an axial cam pump made of hardened stainless steel, enabling it to draw water from an external source when a direct water connection is unavailable. It comes with a 25-foot high-pressure hose, a variable pressure wand, and an on-board detergent tank. The G2000MK is designed for cleaning tasks around the home, such as cleaning siding, patio furniture, vehicles, decks, and driveways. Its compact size and light weight make it portable and suitable for those with limited storage space.
Technical Specifications
  • Model Number: G2000MK
  • Product Type: Pressure Washer
  • Power Source: 87cc Karcher GC series engine
  • Pressure: 2000 PSI
  • Water Flow Rate: 2.0 GPM
  • Power Rating: 1.7 kW
  • Fuel Tank Capacity: 0.95 gallons
  • Detergent Tank Capacity: 0.8 gallons
  • Dimensions: 16 x 19.9 x 23 inches
  • Weight: 54.8 lbs
Warranty
The Karcher G2000MK pressure washer comes with a 2-year limited warranty. This warranty covers defects in the material and workmanship of the product, ensuring that customers receive a reliable, high-quality product. It's important to note, however, that consumable parts such as pumps, hoses, and accessories are not included in the warranty coverage. Additionally, any damage resulting from improper use or lack of maintenance is not covered under this warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 45
All Time: 441
