No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
C601H
Background
The Husky Air Compressor C601H is a portable air compressor. It is used for a range of tasks from home DIY to automotive service and light professional usage. With a 6 HP motor which operates at 120V and 15A, it is capable of producing a maximum pressure of 135 PSI. The tank has a capacity of 6 gallons, and the air delivery rate is 5.7 SCFM at 90 PSI. The pump of this air compressor is lubricated by oil, and the power cord is 6 feet long. The dimensions of the air compressor are 24 x 17 x 25 inches, and it weighs 97 lbs.
This air compressor has a cast iron, V-twin cylinder pump, which is known for its durability and low noise. The oil-lubricated design aids in cooler operation. It comes with an integrated regulator and quick connect coupler, which can be used for inflating tires and running pneumatic tools. The 6-gallon tank allows for longer run times between refills. The tank also recharges rapidly, going from 90 to 135 PSI in less than 2 minutes. The air compressor is suitable for powering air tools like impact wrenches, ratchets, spray guns, nailers, and airbrushes. It can also be used for tires, airbrushing, blow cleaning, and other inflation needs. Regular oil changes are required to ensure optimal performance.
Technical Specifications
  • Motor: 6 HP, 120V, 15A
  • Tank capacity: 6 gallon
  • Max pressure: 135 PSI
  • Air delivery: 5.7 SCFM at 90 PSI
  • Pump type: Oil-lubricated
  • Power cord length: 6 ft
  • Dimensions: 24 x 17 x 25 in
  • Weight: 97 lbs
Warranty
The Husky Air Compressor C601H comes with a 2 year limited warranty. This warranty covers any defects in materials and workmanship. In order to claim the warranty, the original owner must provide proof of purchase. It's important to note that the warranty does not cover damages resulting from misuse, alterations, or improper maintenance of the product.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 310
