Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
C041H
Background
The Husky Air Compressor C041H is a compact, portable air compressor produced by Husky Tools. It is primarily intended for home use and light-duty tasks in a workshop setting.
The specifications of this air compressor include a 1.5 HP oil-free pump, which is powered by connecting to a 120V electrical outlet. It has a tank capacity of 4 gallons, can produce a maximum pressure of 135 PSI, and delivers airflow at a rate of 2.6 SCFM at 90 PSI. The noise level is 78 dBA, and its physical dimensions are 20 x 17 x 18 inches with a weight of 32 lbs. Features such as a portable design with carrying handle, rubber feet, quick connect air couplers, a pressure regulator with gauges, thermal overload protection, and an auto start/stop feature are also present. The C041H air compressor is typically used with light-duty nail guns and staplers, and for inflating tires and sports equipment as well as blowing clean work areas. The oil-free pump eliminates the need for maintenance.
Technical Specifications
  • Model Number: C041H
  • Product Type: Portable Air Compressor
  • Power Source: 120V Electrical Outlet
  • Motor: 1.5 HP Oil-Free Pump
  • Tank Capacity: 4 Gallons
  • Max Pressure: 135 PSI
  • Air Delivery: 2.6 SCFM @ 90 PSI
  • Noise Level: 78 dBA
  • Dimensions: 20 x 17 x 18 Inches
  • Weight: 32 lbs
Warranty
The Husky Air Compressor C041H is provided with a 2 year limited warranty. This warranty covers defects that may occur in the materials and workmanship of the product. However, it's important to note that standard wear items, such as air filters, are not included in this warranty coverage. In order to claim the warranty, users are required to provide proof of purchase and the date of purchase.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 47
All Time: 490
