No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
2G110DP
Background
The Husky Air Compressor 2G110DP is a type of portable air compressor. Its key feature is a 2 horsepower direct drive reciprocating pump, which delivers a rate of 2 gallons per minute at 90 pounds per square inch. This model also includes a 2 gallon twin stack air tank. The compressor has a high flow regulator to optimize air tool performance. The physical parameters include a weight of 40 pounds and dimensions of 20 x 12 x 22 inches.
The Husky 2G110DP is designed for a range of uses including general inflation, blowing, usage with smaller nailers and staplers, and airbrushing. It includes a roll cage frame with wheels and a handle for transportability. The pump is lubricated with oil to ensure cool operation and longevity. It is equipped with an on/off switch and pressure gauges for monitoring tank and regulator pressure. Regular maintenance of this air compressor includes changing the pump oil and cleaning or replacing air filters. The air tank has a drain valve for removing moisture after each use.
Technical Specifications
  • Model Number: 2G110DP
  • Product Type: Air Compressor
  • Power: 2 hp direct drive reciprocating pump
  • Performance: 2 gallon per minute at 90 pounds per square inch
  • Tank Capacity: 2 gallon twin stack air tank
  • Regulator: High flow regulator to maximize air tool performance
  • Weight: 40 pounds
  • Dimensions: 20 x 12 x 22 inches
  • Use: General inflation, blowing, smaller nailers and staplers, airbrushing
  • Portability: Roll cage frame with flat free wheels and handle
  • Pump Lubrication: Oil-lubricated pump
  • Control: On/off switch and pressure gauges to monitor tank and regulator pressure
Warranty
The Husky Air Compressor 2G110DP comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship. However, it is important to note that normal wear items such as air filters are not covered under this warranty. In order to claim the warranty, it is necessary to provide proof of purchase. Additionally, the warranty only applies to the original owners of the product.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 30
All Time: 440
