No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Models
2G110DPNG
Background
The Husky Air Compressor 2G110DPNG is a portable air compressor. It is intended for light-duty applications and intermittent use, such as powering various pneumatic tools including nailers, staplers, and spray guns.
The Husky 2G110DPNG has a 2-gallon air tank capacity, a 1.1 HP induction motor, and a maximum pressure of 110 PSI. It operates on a 120V power source and delivers 0.7 SCFM at 90 PSI. The air tank is constructed from 16-gauge welded steel and the overall weight of the unit is 29 lbs. The compressor features an oil-free design with a maintenance-free pump, and it includes an integrated handle for portability. The control panel consists of an on/off power switch, a regulator knob to adjust pressure settings, and pressure gauges to observe tank and regulated pressure. The 2G110DPNG also comes with a 25' PVC air hose, along with inflation needles and plugs for use with pneumatic tires and inflatables. Typical uses of this air compressor include powering various air tools, inflating tires and sports equipment, and running low CFM spray guns for tasks like painting, staining, and dust blowing. Regular maintenance of this model includes routine checks and cleaning of the air filter, and regular draining of the air tank to prevent moisture buildup.
Technical Specifications
  • Model Number: 2G110DPNG
  • Product Type: Air Compressor
  • Manufacturer: Husky Tools
  • Usage: Portable, light-duty applications, occasional use
  • Air Tank Capacity: 2 gallons
  • Max Pressure: 110 PSI
  • Motor Power: 1.1 HP induction motor
  • Power Requirement: 120V
  • Air Delivery: 0.7 SCFM @ 90 PSI
  • Air Tank Material: 16 gauge welded steel
  • Weight: 29 lbs
  • Additional Features: Integrated handle, control panel with on/off switch, regulator knob, pressure gauges
  • Included Accessories: 25' PVC air hose, inflation needles and plugs
  • Function: Powering nail guns, inflating tires and inflatables, running low CFM spray guns, air brushing, air tool operation
  • Operating Time: 25-30 minutes before needing tank replenishment.
Warranty
The product, Husky Air Compressor 2G110DPNG, comes with a 2-year limited warranty. This warranty covers the air tank of the compressor, ensuring protection against manufacturing defects and functionality issues within the stated period. To claim the warranty, one would likely need to provide proof of purchase and contact the Husky Tools customer service for further assistance. However, specific details regarding the warranty claim process are not mentioned in the provided document and may need to be sought directly from the manufacturer.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 6
Past 7 Days: 12
Past 30 Days: 33
All Time: 550
