Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
DAG450-S
Background
The Hilti Angle Grinder DAG450S 2011 is a hand-held grinding and cutting tool designed for use in the construction and metalworking industries. It features a 4.5-inch diameter grinding wheel, a powerful 7.5-amp motor, and a durable all-metal gearbox that delivers high performance and long-lasting durability.
The Hilti Angle Grinder DAG450S 2011 was introduced in 2011 as an upgraded version of the original Hilti Angle Grinder 450S. The DAG450S model was designed with improved features, including a dust-resistant motor, a tool-free guard adjustment system, and a larger spindle lock button for easier wheel changes.
Like its predecessor, the Hilti Angle Grinder DAG450S 2011 is a popular choice among professionals in the construction and metalworking industries due to its durability, reliability, and safety features. It is a high-quality tool that can handle a wide range of grinding and cutting applications with ease, making it a valuable addition to any toolbox.
Identification
This model of Hilti Angle Grinder can be identified by the model number DAG450S in the tool itself. Hilti tools usually have a date code on them that tells you the year and month of manufacture. For the DAG450S grinder from 2011, the date code should start with the number "11".
Technical Specifications
- Rated Voltage: 120V
- Rated current input: 7.5A
- Rated frequency: 60Hz
- Rated speed: 10,000/min
- Cutting disc: ∅ Max. 4.5"
- Dimensions (L x H x W) without DAG 450‐S hood: 271 mm (10.67") x 103 mm (4.06") x 78 mm (3.07")
- Weight of tool: 2.0 kg (4.41 lb)
Source: Hilti Angle Grinder 450S operation manual
