Shop the Holiday Gift Guide
Ask a Question
There are no questions. Be the first to ask a question!
I-Pro Series 7 Plus
The Haier I-Pro Series 7 Plus washing machine is equipped with a 525 diameter XL drum that allows you to wash larger loads from the comfort of your home. Due to connectivity features implemented in this machine, you will be able to control everything from your mobile phone, using Haier's hOn App. The advanced Direct Motion Motor will save you energy and time, while ensuring less noise and less vibration even during the most demanding washing cycles. If you would like to have time flexibility for your washing cycle, look no further. With "I-Time" feature you can be fully in charge of your cycle duration being able to adjust the cycle timing. With I-Pro Series 7 Plus you will enjoy "Refresh", an innovative micro vapor technology will remove odours, allergens and fine dust while reducing the creases through a 20 minute gentle steam cycle.
Refreshed, professional results at home
Keep odours, fine dust and allergens at bay with the Refresh programme. Vapour technology combines warm air flow and soft micro-steam molecules with accurate temperature control, to permeate the fibres in your fabrics, leaving them clean, soft, and wrinkle-free.
A Class Energy Rating
Choosing Haier’s A Class Washing Machine means saving energy, improving performance efficiency and protecting the environment. It promises at least -51% consumption compared to the G Class machines on the market.
Super silent performance for peaceful living
Enjoy more peace and quiet at home with the Direct Motion Motor. Unlike standard motors, it doesn’t operate with a belt and pulley system. Instead, the motor is attached directly to the drum, significantly reducing noise, vibrations and energy consumption. Making it perfect for open plan living.
Extra hygiene for your laundry
Haier’s incredibly useful Smart Dual Spray is an automatic cleaning system for your washing machine that is activated at the end of each wash cycle. Not only does this ensure a more hygienic wash for your laundry, it also improves the durability of your machine in the long run.
Antibacterial treatment for a cleaner machine
The exclusive Haier material protects the most sensitive areas of your washing machine. Haier's Anti-Bacterial Treatment (ABT) protects against mould and bacteria forming in vulnerable areas, such as the detergent drawer and porthole gasket for a more hygienic laundry cycle by up to 99%.
Connected to your needs
hOn, the new Haier app is here. Constantly updated, it provides you the best-in-class features and tailored results. It allows you to easily choose and customize from more than 60 specialized cycles for each type of fabric, to access convenient tips on stain treatment and ad hoc tips on the type and quantity of detergent. You can also choose the perfect moment to start your laundry according to the weather conditions. With hOn, you can constantly monitor efficiency and consumption and receive suggestions on how to optimise them. You can also access self-maintenance planning, to maintain the reliability and performance of your washing machine over time. All this with the possibility of managing and controlling the washing status at any time, even outside the home and receiving notifications when the cycle is complete. Discover all the advantages that will prove that the hOn App is your will allow you to obtain professional laundry results at home.
Illuminate your laundry
Thanks to the drum's handy interior light, you can load and unload your laundry easily without leaving anything behind. Say goodbye to the quest for lost socks!
Personalise your connected machine to your needs
Haier design appliances that adapt to your life. Connected, customisable and tailored to you, the hOn App allows you to personalise your washing machine so it fits around you.
Control when the cycle ends
An incredibly convenient feature that allows you to select when you want your washing cycle to finish. Simply decide when you need your cycle to end and the washing machine will automatically calculate the starting time. So now you can make sure your laundry fits around your life, and not the other way around!
Control the duration of your wash
Haier’s clever ‘I-Time’ function allows you to fine tune the duration of the wash, so you can shorten or lengthen the duration of your laundry cycle based on your needs.
Wide access for easier loading
At 36 cm wide, the washing machine's opening is one of the largest on the market. It has been specially designed so it can open to a wide angle, making loading and unloading far easier for bulky fabrics and large laundry loads.
Author
with
Kirbo
1,946 Reputation
1 Guide authored
Past 24 Hours: 8
Past 7 Days: 39
Past 30 Days: 184
All Time: 362
