Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background on the MediaPad M5 Lite 10:
The MediaPad M5 Lite is a tablet running Android 8.0 Oreo and is not affected by the absence of the Google Play Store.
Equipped with a Kirin 659 processor with 3 or 4 GB of RAM and 32, 64, or 128 GB of storage, its performance is average for tablets of its time (Antutu score of 75,400). The display panel is a 10.1-inch Full HD IPS screen paired with four Harman Kardon speakers and, most notably, a fingerprint sensor on the central button of the screen. The internal memory can be expanded by SD card up to 256 GB maximum.
User feedback on this tablet is generally positive, especially for multimedia uses (audio, video, reading, and web browsing).
Identifying the MediaPad M5 Lite 10:
The Huawei brand name is present on the front face at the top left, with the central button at the bottom center. On the back, the Huawei name is also found, with the harman/kardon name below it, and the model number in very small print underneath that.
The MediaPad M5 lite exists on the French market under two model numbers:
-> BAH2-L09
-> BAH2-W19
These two models have a similar internal layout.
The tablet has rounded sides, which makes it quite comfortable to hold.
Specifications of the MediaPad M5 lite
Physical characteristics:
Length: 243.4 mm
Height: 162.2 mm
Thickness: 7.7 mm
Weight: 475g
Processor:
Huawei HiSilicon KIRIN 659 (eight cores organized as 4x Cortex•A53 2.36 GHz + 4x Cortex•A53 1.7 GHz)
Graphics Processor:
ARM Mali-T830 MP2
RAM:
The tablet is equipped, depending on the options, with 3 or 4GB of LPDDR3 RAM
Internal memory:
32, 64 GB, or 128 GB.
SD slot: 256GB maximum (microSD Flash)
Display:
10.1-inch Full HD IPS LCD screen
Resolution: 1920 x 1200 pixels
Brightness: 400 cd/m²
Contrast ratio: 1000:1
Pixel density: 224 PPI
Sound:
4 Harman-Kardon speakers
Connectivity:
* LTE model only:
Bands:
4G: LTEB1 (2100), B3 (1800), B5 (850), B7 (2600), B8 (900), B20 (800), B34 (TDD 2100), B38 (TDD 2600), B39 (TDD 1900), B40 (TDD 2300), B41 (TDD 2500)
3G: B1 (2100), B2 (1900), B5 (850), B8 (900), B34 (TD 2000), B39 (TD 1900+)
2G: CDMA BC0 (800), B2 (1900), B3 (1800), B5 (850), B8 (900)
Satellite navigation: GPS, A-GPS, GLONASS, Beidou
  • All models:
Wi-Fi:
Bands: 802.11a, 802.11b, 802.11g, 802.11n, 802.11n 5GHz
Functions: Dual band, Wi-Fi hotspot, and Wi-Fi Direct
Bluetooth:
Version: 4.2 LE (low energy consumption)
Profiles: A2DP (Advanced Audio Distribution Profile), EDR (Enhanced Data Rate), and LE (Low Energy)
Ports:
All on the left:
Audio: 3.5 mm jack socket
USB: USB-C (likely 2.0, but I cannot confirm this point)
Tray: - SD slot
- nano-SIM (for LTE model only)
Cameras:
Front camera (selfie) centered on the length: 8 MP.
Rear camera at the top left: 8 MP.
Sensors:
  • Fingerprint: Yes
  • Proximity: Yes
  • Ambient light: Yes
  • Accelerometer: Yes
  • Compass: Yes
  • Hall: Yes
Sources and information:
Huawei official site for support of the Mediapad M5 lite 10: https://consumer.huawei.com/fr/tablets/m...
Performance and technical information on kimovil.com: https://www.kimovil.com/fr/ou-acheter-hu...
Presentation of the machine on the site Frandroid.fr: https://www.frandroid.com/produits/table....
Gredin973
2,579 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 87
All Time: 640
