1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
17G180
Background
The Graco Paint Sprayer 17G180, also known as the ProX19 Magnum, is an electric airless paint sprayer. It is designed to spray unthinned paints and stains and is suitable for small residential and commercial painting projects.
This paint sprayer is powered by a 0.65 kW DC motor and a 120V, 60Hz electric power source. It has a maximum pressure of 3000 psi, adjustable for different needs. The sprayer can accommodate a maximum tip size of 0.019 inches and has a maximum flow rate of 0.38 gallons per minute. It uses a piston pump and features a 35 mesh stainless steel inlet strainer. Its outlet filter, known as InstaClean, helps maintain the cleanliness of the device. It can support a maximum hose length of 150 feet. The sprayer is designed with stainless steel, aluminum, brass, nylon, and PVC parts. It is portable, being encompassed in a cart frame, and weighs 38 lb. The sprayer's dimensions are 36.7 in x 20.2 in x 17.2 in.
The Graco Paint Sprayer 17G180 is designed to handle a range of painting jobs, from fences and decks to interior walls, cabinets and doors. It can also be used for crafts and small industrial applications. The sprayer is compatible with multiple tip sizes and can handle up to 500 gallons of paint per year.
Technical Specifications
- Power source: 120V, 60Hz electric
- Motor: 0.65 kW DC motor
- Power rating: 653W
- Amperage: 8A
- Pressure control: Adjustable, up to 3000 psi
- Max tip size: 0.019 in
- Max flow rate: 0.38 GPM (1.4 L/min)
- Pump type: Piston
- Inlet strainer: 35 mesh stainless steel
- Outlet filter: InstaClean
- Max hose length: 150 ft (45 m)
- Weight: 38 lb (19 kg)
- Dimensions: 36.7 in x 20.2 in x 17.2 in (93 cm x 51 cm x 43 cm)
- Wetted parts: Stainless steel, aluminum, brass, nylon, PVC
Warranty
The Graco ProX19 Magnum Airless Paint Sprayer comes with a warranty that lasts for 1 year. This warranty covers defects in materials and workmanship of the product. However, it's important to note that the warranty does not cover any damage that results from improper use or general wear and tear. If you encounter any issues that fall under the warranty's coverage within the 1-year period, you can claim the warranty to have them addressed.
Graco Magnum ProX17, ProX19, ProX21 and ProLTS170–190 Owner's Manual
