No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
16N673
Background
The Graco Paint Sprayer 16N673 is a handheld, corded airless paint sprayer. It is part of a series of paint sprayers intended for professional use. The product operates on 120V AC power, and has a 186W, 0.25 HP motor. The sprayer utilizes a Triax Triple Piston pump and can reach a maximum pressure of 138 bar (2000 psi). Weighing 2 kg (5 lb) and with dimensions of 267 mm x 361 mm x 127 mm (10.5 in x 14 in x 5 in), it also includes a hose of length 457 mm (18 in). The product is compatible with tip sizes ranging from 0.008 to 0.016 in, with a maximum tip size of 0.016 in. It is recommended for an annual usage of 50 gallons.
The Graco Paint Sprayer 16N673 is designed for portability and includes onboard hose and cord storage for convenience. It features adjustable pressure control for versatility with different coatings and uses a FlexLiner bag system for quick material changes. The product comes with a TC Pro 514 spray tip, 60 mesh filter, Pump Armor storage fluid, a storage bag, and accessories. It is suitable for small residential, commercial, industrial, and marine projects. The triple piston pump allows it to spray unthinned paints and stains at high pressure. The FlexLiner system allows for quick material changes by using disposable paint bags. It ships with a TC Pro 514 spray tip installed and also accepts tips from 0.008 in to 0.016 in for use with various coatings. With adjustable pressure up to 2000 psi, it can spray light stains or heavy latex house paint.
Technical Specifications
  • Model Number: 16N673
  • Product Type: Handheld Corded Airless Paint Sprayer
  • Power: 120V AC, 186W, 0.25 HP
  • Motor: Triax Triple Piston pump
  • Max Pressure: 138 bar (2000 psi)
  • Weight: 2 kg (5 lb)
  • Dimensions: 267 mm x 361 mm x 127 mm (10.5 in x 14 in x 5 in)
  • Hose Length: 457 mm (18 in)
  • Compatible Tip Sizes: 0.008, 0.010, 0.012, 0.014, 0.016 in
  • Maximum Tip Size: 0.016 in
  • Recommended Annual Usage: 50 gallons
Warranty
The Graco Paint Sprayer 16N673 comes with a standard 1 year warranty provided by Graco. This warranty covers any defects in the materials and workmanship of the product for a period of 1 year from the date of purchase. However, it's important to note that this warranty does not provide coverage for any damage that results from misuse or improper maintenance of the product. To claim the warranty, you would typically need to contact Graco's customer service with proof of purchase and details of the defect.
Graco 120V Fixed- and Adjustable-Pressure Electric Hand-Held Paint Sprayers Operation, Repair and Parts Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 37
All Time: 296
