Ask a Question
There are no questions. Be the first to ask a question!
Documents
2014–2020 Ford Transit Courier Technical Specs
Engine and Performance
  • 1.0L EcoBoost Petrol: 3-cylinder turbo producing 100 PS (99 hp) and 125 lb-ft} of torque.
  • 1.5L Duratorq TDCi Diesel: Producing 75 PS (74hp) and 140 lb-ft of torque.
  • 1.6L Duratorq TDCi Diesel: Producing 95 PS (94 hp) and 158 lb-ft of torque (later replaced by a higher-output 1.5L unit).
  • Top Speed: Approximately 106 to 108 mph depending on the engine.
Drivetrain and Transmission
  • Drive Type: Front-Wheel Drive (FWD).
  • Transmission: Primarily a 5-speed manual for early models, with 6-speed manuals introduced later in the production run to improve highway fuel economy.
  • Efficiency: Notable for its "best-in-class" economy at launch, with the 1.6L diesel capable of over 70 mpg on the European cycle.
Chassis and Load Capacity
  • Suspension: MacPherson struts (front) and a twist-beam rear suspension with dual-rate springs to handle heavy loads without ruining the unladen ride quality.
  • Payload: Maximum payload capacity of up to 660 kg (1,455lbs).
  • Brakes: Ventilated discs (front) and drums (rear) as standard.
  • Wheels: 15-inch steel or alloy wheels depending on trim (Base, Trend, or Limited).
Dimensions
  • Overall Length: 163.7 inches (4,157 mm).
  • Wheelbase: 98 inches (2,489 mm).
  • Load Volume: 81 cubic feet (2.3 m^3) with a standard bulkhead.
  • Turning Circle: A very tight 10.5 meters, making it ideal for U-turns in narrow streets.
oldturkey03
863,265 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
71 Members
3,050 Guides authored
Past 24 Hours: 13
Past 7 Days: 43
Past 30 Days: 189
All Time: 1,119
