No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
D28115
Background
Dewalt Angle Grinder D28115 - TYPE 2 (2016) is a high performance angle grinder. It is used to deliver industrial-grade power in compact form. The type 2 version came out in 2016 and the design is only different internally.
There are no major differences from earlier version externally. The big difference between type 1 and 2 is there are safer measures and faster and better motor components.
Its primary use is metal cutting and grinding, removing rust and paint, and construction work. The compact design and low-profile head make it ideal for tight spaces and it has a dust ejection system. It also has a 13 amp motor and high torque and speed (9000 rpm).
Identification
To find the correct device check the nameplate / rating label on the side or bottom of the grinders motor. It will provide the brand model number and type. It has yellow/black housing with molded vents. Also to double check if you got the right model the manual will have the model and type on the front.
Technical Specifications
  • Motor: 13.0 amp
  • Speed: 9000 RPM
  • Weight: 4.2 lb
  • Width: 18 in
  • Spindle Thread: 5/8-11 (corded)
  • Dust Ejection System
  • Source: DeWalt Contractor supply
Additional Information
Contractor Supply
Syndigo pdf
Tool Source
DeWalt Official Page
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 28
All Time: 220
