1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
D28112
BACKGROUND:
The Dewalt Angle Grinder D28112 TYPE 2 2016 has a 10 Amp AC/DC 11,000 RPM motor capable of performing heavy duty tasks. Its low profile and gear alignment allows for easy access to tighter spaces and quieter noise operation. One distinguishing feature is the automatic shutoff system that activates when the motor brushes wear out, indicating the need for a new brush. The tool also includes an internal dust ejection system designed to keep debris from building up inside, helping maintain performance over time.
The D28112 is most notable for its aggressive material and material removal in areas such as metalworking, masonry, and concrete applications.
IDENTIFICATION:
The Dewalt Angle Grinder D28112 TYPE 2 2016 is a handheld grinder that has a black and yellow finish on the lock-on slide switch side of the device. The other part of the device is a separate all black handle with the debris guard attached to it for more precise control.
TECHNICAL SPECIFICATIONS:
·      10-amp AC/DC 11,000 RPM
·      Max watts out: 1,200 W
·      4-1/2 in. small angle grinder
·      Tool Length: 11-¼"
·      Spindle thread: 5/8”-11
·      Tool weight: 4.6 lbs.
·      Lock-on slide switch
·      2-position side handle
·      Keyless adjustable guard
·      Wrench
·      1-piece brush arm
·      Jam-pot gear case
·      Spindle lock button
·      Dimensions: Depth (in.), 5.94 in, Height (in.), 4.81 in, Width (in.), 15.63 in, Wheel Diameter (in.), 4.5 in
ADDITIONAL INFORMATION:
For parts, manuals, and diagrams for the DeWalt D28112 TYPE 2, here are some helpful resources:
·      Dewalt 10-amp Angle Grinder D28112
·      Sears Parts and Replacement guides
·      Replacement parts
For disposal and recycling information:
·      Recycle and disposal
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 55
All Time: 691
