No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Documents
Models
315.1172
Background
The Craftsman 3-inch Belt Sander, model number 315.11720, is a handheld electric sander that is capable of sanding various materials including wood, metal, and plastics. The product, manufactured by Diehl Mfg Co for Sears under the Craftsman brand, is equipped with a 3-inch wide sanding belt powered by a 1/3 HP motor. It operates on a standard 120V AC current and weighs 5 lbs. It also features an auxiliary front handle for two-handed operation, belt tracking adjustment, and an on/off trigger switch.
The design of the sander allows for balanced handling, either with one or two hands, depending on the user's preference. The auxiliary front handle adds an extra dimension of control, enabling the user to keep the sanding surface flat against the workpiece. The sander has adjustable belt tracking, which can be set by turning a screw on the side of the sander while it is running. This helps keep the sanding belt centered and running smoothly. The sander also has a double insulation feature, which means that all exposed metal parts are isolated from internal components, eliminating the need for an external ground connection.
Technical Specifications
  • Model Number: 315.11720
  • Product Type: Handheld Electric Belt Sander
  • Sanding Belt Size: 3-inch wide
  • Motor Power: 1/3 HP
  • Power Source: 120V AC
  • Additional Handle: Auxiliary front handle for two-handed operation
  • Adjustment: Belt tracking adjustment feature
  • Switch: On/off trigger switch
  • Insulation: Double insulated
  • Weight: 5 lbs
Warranty
The Craftsman 3-inch Belt Sander (model 315.11720) comes with a 1-year warranty that covers any defects and issues related to workmanship. In the event that any such problems arise within the first year of your purchase, you can claim the warranty. To do so, you would need to contact Sears parts centers or the place of purchase, provide details of the issue, and present proof of purchase. Do note that the warranty does not cover issues arising from the regular wear and tear of components such as carbon brushes. These should be inspected periodically and replaced when worn down to 1/4 inch length for optimal performance. Regular lubrication with machine oil after several hours of use is also advised for maintaining the performance and longevity of the product.
Craftsman 315.11720 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 68
All Time: 1,047
