1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
919.762
Background
The Craftsman Pressure Washer 919.762000 is a pressure washer manufactured by Ingersoll Rand for Sears. The washer is gasoline-powered and is designed for heavy duty cleaning applications. It operates with a 6 HP engine and an axial cam pump, providing a pressure of up to 2000 PSI and a flow rate of 2 GPM. The washer's power source is gasoline, with a fuel tank capacity of 0.95 gallons. Other specifications include a high pressure hose length of 25 feet and a weight of approximately 60 lbs.
The pressure washer features 10" wheels and a handle for maneuverability. It is equipped with an adjustable spray nozzle that allows the user to select a spray pattern from 0 to 60 degrees. Additionally, the washer has a chemical injection capability for the application of detergents and cleaning chemicals. The washer is operated by adding fuel and engine oil, connecting a garden hose to the water inlet, starting the engine via a recoil starter, unlocking the trigger and squeezing to operate, adjusting the nozzle for the desired spray pattern, and allowing a regular flow of water through the pump to prevent overheating. Maintenance of the washer includes regular checking and changing of engine oil, inspection of hoses and connections for leaks, cleaning of nozzles to prevent clogging, use of pump saver or purging the system before storage, and replacing worn seals and valves to maintain pressure.
Technical Specifications
- Engine: 6 HP
- Pump type: Axial cam pump
- Pressure: Up to 2000 PSI
- Flow rate: 2 GPM
- Power source: Gasoline
- Fuel tank capacity: 0.95 gallons
- High pressure hose length: 25 ft
- Weight: Approximately 60 lbs
- Portability: 10" wheels and handle
- Spray nozzle: Adjustable, 0 to 60 degrees
- Chemical injection: Yes
- Safety features: Trigger lock and thermal relief valve
Warranty
The Craftsman Pressure Washer 919.762000 comes with a one-year limited warranty that is provided through Sears. This warranty covers any defects in materials and workmanship that might occur during normal use. However, it's important to note that wear items such as hoses, nozzles, and seals are not included in this warranty. In the case of the pump and accessories, they are serviced by replacement only. To claim the warranty, contact Sears with details of the defect and provide proof of purchase. Please remember to retain your receipt for this purpose.
