2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
580.752101
Background
The Craftsman 2700 PSi Pressure Washer 580.752101 is a gas-powered pressure washer developed by Goldstar for Sears under the Craftsman brand. It is equipped with a 212cc Briggs & Stratton engine and an axial cam pump. The unit can produce up to 2700 PSI of water pressure and 2.5 GPM of water flow, making it suitable for cleaning a variety of surfaces including concrete, brick, patios, decks, driveways, vehicles, and boats.
The pressure washer includes features such as a 25 foot high pressure hose, a one-gallon detergent tank, and a selector with various nozzles for different degrees of spray. It also comes with wheels and handles for portability, and a storage tray for accessories. The pressure washer operates by connecting a garden hose to the water inlet, priming the pump by squeezing the spray gun trigger, and starting the engine. Detergent, if necessary, can be applied using the onboard tank. After use, it is recommended to flush the detergent system and let the engine cool before storing the unit.
Technical Specifications
- Model Number: 580.752101
- Product Type: Pressure Washer
- Engine: 212cc Briggs & Stratton OHV
- Power Rating: 6.75 HP
- Pump Type: Axial cam pump
- Max Pressure: 2700 PSI
- Max Flow Rate: 2.5 GPM
- High Pressure Hose Length: 25 ft
- Detergent Tank Capacity: 1 gal
- Fuel Tank Capacity: 1.6 qt
- Weight: 71 lbs
Warranty
The Craftsman 2700 PSi Pressure Washer 580.752101 comes with a 2-year limited warranty. This warranty protects against defects in materials and workmanship. Additionally, normal wear items such as pumps, hoses, and nozzles are covered for 90 days from the purchase date. However, please note that misuse or improper maintenance of the product can result in the warranty being voided. To make a warranty claim, it is recommended to contact the manufacturer directly, with contact details available on the Craftsman website or by calling their support phone number at 1-888-331-4569.
