5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
143.975001
Background
The Craftsman 143.975001 also known as the Tecumseh HSSK50 engine is a 33-pound, gasoline powered engine that was produced for Craftsman by the Tecumseh Products Company. This engine was designed to help prevent engine shutdowns during cold weather due to its usage in snowblowers using a "Winter Engineered" outlined in the winter application manual using an intake system that channels warm air into the carburetor area to keep ice buildup at a minimum. The outer cover of the engine is also made of stamped steel, which aids in this effect.
Although it carries a Sears specific model, the engine design, specifications, and parts are all identical to the HSSK50 engine, and was simply built under the brand name as Craftsman sourced engines from major manufacturers, in this case Tecumseh. Any differences between these engines are simply cosmetic in label and minor accessory. Internally they are the same engine.
A known issue that can occur overtime according to technician reports with these engines is the carburetor, where the gas as it ages will turn to varnish and clog up the passages of the carburetor, clogging it and blocking gas from entering the chamber. It is highly recommended with this engine to clean it out periodically if you are not using it.
Identification
Identifying one of these engines is straightforward if you know what you're looking for. The HSSK50 can be identified primarily by the model number stamp. These engines usually have the model number stamped into the metal air cover just above the spark plug. It can also be found in some cases on a metal plate below this area. The engine’s appearance can be identified by a horizontal-cylinder layout. It typically has a black sheet-metal shroud covering the cylinder, a black plastic fuel tank on top with a red cap, and a recoil starter at the front.​
Technical Specifications
Engine Overview
Model: Tecumseh HSSK50
Type: 4-cycle L-head, single-cylinder, gasoline
Horsepower: 5.0 HP
Displacement: 197 cc
Fuel and Oil
Fuel: Unleaded gasoline
Recommended Oil (Winter): SAE 5W-30
Oil Capacity: 0.66 quarts (0.62 liters)
Starting and Ignition
Starting System: Manual recoil starter or optional 120V electric starter
Spark Plug Type: Champion RJ19LM
Spark Plug Gap: 0.030 inches (0.762 mm)
Dimensions and Weight
Length: 16.6 in (420 mm)
Width: 9.3 in (235 mm)
Height: 13.4 in (339 mm)
Weight: 33 lbs. (15.1 kg)
Change Engine Oil: Every 25 operating hours
Clean or Replace Air Cleaner: Every 25–100 hours
Replace Spark Plug: Every 200 hours
Sources: Tecumseh 5.0 Horsepower Winter Application Manual
JustAnswer HSSK50 Technical Assistance
Diesel and Gasoline Engines Specifications and Service Data
Additional Information
Tecumseh HSSK50 Engine Operator’s Manual-This site hosts a downloadable PDF of the operators manual, with operating instructions, maintenance guidelines, specs, and troubleshooting tips.
Sears PartsDirect Craftsman 143.975001 Parts List-This site links to the official Sears parts directory which includes diagrams and OEM parts list for this engine.
HSSK50/143.975001 Engine Parts Manual- This links directly to a PDF including a reference list of parts numbers and an exploded diagram showcasing them all
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 37
All Time: 809
