10 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
536.884582
Background
The Craftsman Electric Snow Thrower 536.884582, manufactured by Western Tool & Stamping for Sears, is a machine designed to clear snow. This electric snow thrower operates through a combination of controls. These include an ignition switch key that must be inserted and turned to the ON position to start the engine, a choke control used to start a cold engine, a primer button that injects fuel directly into the carburetor manifold for fast starts in cold weather, and an electric starter button used to start the engine using the 120V electric starter.
Furthermore, the snow thrower is equipped with an auger control bar to start and stop the auger which propels the machine. The discharge chute changes the direction the snow is thrown, and this direction can be adjusted using the chute control rod. The chute deflector alters the distance the snow is thrown. The snow thrower is also designed with a 2-cycle engine model number 143.983071 and requires a specific oil/fuel mixture for optimum operation. Regular maintenance activities such as tightening screws and nuts, checking spark plugs, drive belts, and fuel, as well as lubricating chute control flange are necessary for maintaining the snow thrower's performance.
Technical Specifications
- Model Number: 536.884582
- Product Type: Electric Snow Thrower
- Engine Type: 2-Cycle
- Cylinder: 490291A
- Crankshaft: 570644
- Ignition: Solid State Ignition
- Spark Plug: Resistor type RCJ6Y
- Carburetor: 510324B
- Starter: Recoil and optional 120V Electric Starter
Warranty
The Craftsman Electric Snow Thrower 536.884582 comes with a limited one-year warranty. This warranty covers any defects in material or workmanship and provides free repairs for one year from the date of purchase, as long as the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins, nor does it cover repairs necessary due to operator abuse or negligence. To claim the warranty, the Craftsman Snow Thrower should be returned to the nearest Sears Service Center Department in the United States. It is important to note that this warranty only applies while the product is in use in the United States.
