3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
536.772321
Background
The Craftsman Edger 536.772321 is a lawn care tool designed for edging and trimming. It is a product of Western Tool & Stamping, manufactured for Sears under the Craftsman Brand. The edger is equipped with several controls and components including the engine stop lever, starter rope handle, depth control lever, air filter, fuel tank, primer button, blade guard, blade, blade guide, and quill assembly. It also features an oil drain plug and carries both an engine model number and a product model number.
This lawn edger is designed with a displacement of 9.02 cubic inches (147.8 cc) and an oil capacity of 20 oz. SAE-30W. The engine's power ratings are developed with the SAE (Society of Automotive Engineers) code J1940. However, the actual on-site power may vary due to factors such as altitude, temperature, barometric pressure, humidity, fuel, engine lubrication, engine speed, design of the equipment, operation manner, engine run-in, and adjustments to the valves and carburetor. The edger is intended solely for lawn care edging and trimming.
Technical Specifications
  • Product Model Number: 536.772321
  • Displacement: 9.02 cu. in. (147.8 cc)
  • Oil Capacity: 20 oz. SAE-30W
  • Bore: 2-9/16 in. (65.09 mm)
Warranty
The warranty for the Craftsman Edger 536.772321 is valid for one year from the date of purchase. This warranty covers any defects in material or workmanship. If the edger fails within the warranty period, it can be returned to any Sears store, Sears Parts & Repair Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, the warranty does not cover expendable parts such as spark plugs, blades, or belts, which can wear out in less than a year due to normal use. Additionally, if the edger is used for commercial or rental purposes, the warranty period is reduced to 90 days. To claim the warranty, customers can bring the defective edger to an authorized Sears service dealer, where the warranted part will be repaired or replaced at no cost, including diagnostic labor. It is important to note that warranty coverage may be denied if the failure is due to abuse, neglect, improper maintenance, or unauthorized modifications.
Craftsman 536.772321 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 567
