No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.36068, 358.360680
Background
The Craftsman Chain Saw 358.360680, manufactured by Poulan/Weedeater for Sears, is a gasoline-powered tool used for cutting wood. The product is equipped with several features that aid its operation. Notable among these is an ON/STOP switch that controls the engine, a throttle trigger that regulates engine speed, and a throttle lock-out to prevent accidental triggering. Additionally, it has a choke/fast idle lever that aids in cold starting or after refueling by providing additional fuel to the engine.
The chain saw includes a primer bulb that circulates fuel to the carburetor for quicker starting. It also has a chain brake designed to stop the chain if kickback occurs, which can be activated manually or automatically. The saw features a chain tension system, which is important as a new chain typically stretches during the first 15 minutes of operation. The saw also has a muffler that is important for the operation of the chainsaw.
Technical Specifications
  • Product Type: Chain Saw
  • Model Number: 358.360680
  • Cubic Capacity: 2.2 cu.in./36cc
  • Cycle Type: 2-Cycle
  • Fuel Type: Gasoline
  • Bar Length: 16 in
  • Features: Front Hand Guard, Starter Rope, ON/STOP Switch, Choke/Idle Lever, Muffler, Bar Oil Fill Cap, Starter Housing, Fuel Mix Fill Cap, Primer Bulb, Cylinder Cover, Throttle Lockout, Rear Handle, Throttle Trigger, Clutch Cover, Chain Brake
  • Chain Brake: Device designed to stop the chain if kickback occurs. Activates automatically in the event of kickback and manually if the front hand guard is pushed forward.
  • Certification: Listed by Underwriters Laboratories, Inc. in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-2000).
  • Spark Arresting Screen: Equipped with a temperature limiting muffler and spark arresting screen which meets the requirements of California Codes 4442 and 4443.
Warranty
The warranty for the Craftsman Chain Saw 358.360680 is a full one-year warranty. Within this one-year period, Sears will repair any defect in material or workmanship free of charge, as long as the chainsaw is maintained, lubricated, and tuned up according to the instruction manual. However, it is important to note that the warranty excludes the bar, chain, spark plug, and air filter, as these are considered expendable parts that may become worn during normal use. If the chainsaw is used for commercial or rental purposes, the warranty applies for only 30 days from the date of purchase. To claim the warranty, customers can return the chainsaw to the nearest Sears store or service center in the United States. It is advisable to contact the authorized service center or call Sears at 1-800-469-4663 for any questions regarding warranty rights and responsibilities.
Craftsman 358.360680 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 271
