No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.3601
Background
The Craftsman Chain Saw 358.360100 is a gasoline-powered tool designed to facilitate cutting tasks. It is equipped with a 2.2 cubic inch/36cc 2-cycle engine and a 16-inch bar. This model includes various features to enhance its operation and user experience. It has a front handle and a rear handle for secure grip during operation. The on/stop switch is used to halt the engine.
The throttle trigger on this chain saw helps to control engine speed. The throttle lockout feature requires to be pressed before the throttle trigger can be squeezed, preventing accidental activation of the trigger. There is also a fast idle lock that holds the throttle trigger in the starting position. A choke knob is used to provide additional fuel to the engine during cold starting. This model also includes a primer bulb that circulates fuel to the carburetor for quicker starting.
The chain brake is designed to stop the chain in case of kickback. It can be activated automatically or manually by pushing the front hand guard forward. The chain brake is disengaged by pulling the front hand guard back toward the front handle. The chain tension can be adjusted as it is normal for a new chain to stretch during the first 15 minutes of operation.
This chain saw is designed for occasional use and is suitable for a variety of cutting tasks.
Technical Specifications
  • Model Number: 358.360100
  • Product Type: Chain Saw
  • Engine: 2.2 cu.in./36cc 2-Cycle Gasoline
  • Bar Length: 16 in.
  • Controls: ON/STOP SWITCH, THROTTLE TRIGGER, THROTTLE LOCKOUT, FAST IDLE LOCK, CHOKE KNOB, PRIMER BULB, Chain brake, Chain Tension adjustment knob
  • Fuel: Gasoline
  • Additional Features: Chain brake device designed to stop chain if kickback occurs, Chain tension adjustment available
Warranty
The Craftsman Chain Saw 358.360100 comes with a warranty period of two years from the initial date of purchase. The warranty covers the repair or replacement of any warranted part at no charge to the owner at an approved Sears servicing center. The warranty does not cover failures caused by abuse, neglect, or improper maintenance. If a problem exists, the owner should present the lawn and garden equipment engine to a Sears authorized repair center as soon as possible. Warranty repairs should be completed in a reasonable amount of time, not exceeding 30 days. To claim the warranty or for any questions regarding warranty rights and responsibilities, the owner can contact their nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.360100 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 33
All Time: 424
