Shop the Holiday Gift Guide
No Image
This wiki is missing a device image. Help improve this page by uploading one!
4 Diagrams
Documents
Models
358.354871
Background
The Craftsman Chain Saw 358.354871 is a versatile tool designed for various cutting tasks. Manufactured by Poulan/Weedeater for Sears, it is a standard chainsaw model which operates on fuel. The chainsaw is equipped with an automatic and manual oil pump for lubrication of the chain, ensuring smoother operation. It also features a manual oiler lever, an isolator for reducing vibrations, and a throttle lock for safety and control. The chainsaw is designed for cutting wood and is suitable for handling small size brush and saplings.
One of the key characteristics of the Craftsman Chain Saw 358.354871 is its repairability. The chainsaw is assembled with numerous parts that can be independently replaced or repaired if they malfunction. These parts range from the engine components, such as the carburetor and fuel tank, to the oil pump and chainsaw guide bar. The chainsaw also comes with a choke rod, a handlebar assembly, and an oil line pick-up assembly, among other parts. This modularity allows for easier maintenance and extends the longevity of the chainsaw.
Technical Specifications
  • Model Number: 358.354871
  • Product Type: Chain Saw
  • Engine: 3.7/18"PS
  • Ignition, Cooling, and Exhaust Systems: Includes carbon deposits that build up on exhaust parts, spark arrestor, muffler, and spark plug. These parts should be cleaned regularly to prevent engine damage, overheating, loss of power, and hard starting.
  • Spark Plug: Needs to be kept clean and properly gapped (.025"). Maintenance is required when the engine is hard to start.
  • Fuel: Needs to be handled with caution. Eliminate all sources of sparks or flame in the areas where fuel is mixed, poured, or stored. The saw should be moved at least 10 feet away from the fuel and fueling site before starting the engine.
  • Cutting Technique: The saw should only be used to cut wood. The chain should be kept out of dirt and sand to prevent dulling. The engine should be at full throttle during the entire time of cutting. The saw should be stopped before setting it down after cutting.
  • Tree Felling Techniques: The sawing operation needs to be planned carefully in advance. The work area should be clear and secure. The falling direction of the tree needs to be assessed based on the wind, lean of the tree, and the side that is heaviest with branches. A clear retreat path to the rear and diagonal to the line of fall is needed.
Warranty
The Craftsman Chain Saw 358.354871 comes with a full one-year warranty on the gasoline chain saw, excluding the bar, chain, spark plug, air filter, and starter rope, which are considered expendable parts. This warranty covers defects in material or workmanship and is valid for one year from the date of purchase. To claim the warranty, it is necessary to maintain, lubricate, and tune up the chain saw according to the operating and maintenance instructions in the owner's manual. Warranty service can be availed by returning the chain saw to the nearest Sears store or service center in the United States. It is important to note that this warranty does not cover commercial or rental use, and specific legal rights may vary from state to state.
Craftsman 358.354871 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 56
All Time: 558
