No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35268
Background
The Craftsman Chain Saw 358.352680 is a gasoline-powered tool manufactured by Poulan/WeedEater for Sears. This chain saw is equipped with several features that aid in its operation. It has a 2.6 cubic inch/42cc 2-cycle engine and an 18-inch bar for cutting through wood. Its controls and adjustments are designed for user convenience, and include an ON/STOP switch, a throttle trigger, a throttle lockout, a fast idle lock, a choke knob, and a primer bulb.
The ON/STOP switch is used to halt the engine, while the throttle trigger controls engine speed. The throttle lockout must be pressed before the throttle trigger can be squeezed, preventing accidental operation. The fast idle lock holds the throttle trigger in the starting position for easier starting. The choke knob activates the choke to supply additional fuel to the engine during cold starts, while the primer bulb circulates fuel to the carburetor to facilitate quicker starting. The chain tension can be adjusted as needed, as it is normal for new chains to stretch during the first 30 minutes of operation.
Technical Specifications
  • Model Number: 358.352680
  • Product Type: Gasoline Chain Saw
  • Engine: 2.6 cu. in./42cc, 2-Cycle
  • Bar Size: 18 in.
  • Features: Chain Brake, Spark Arrestor
  • Compliance: Meets the requirements of California Codes 4442 and 4443 for spark arrestor screen.
  • Standard Compliance: Listed by Underwriters Laboratories, in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-1991).
  • Contents: Chain Saw (fully assembled), Bar tool, Chain, Carrying Case, Gloves, Gas Can, Bar & Chain Lube, 2-cycle engine oil.
  • Controls: ON/STOP Switch, Throttle Trigger, Throttle Lockout, Fast Idle Lock, Choke Knob, Primer Bulb.
  • Chain Tension: Adjustable
  • Fuel Type: Gasoline
  • Assembly: Saw is fully assembled, no further assembly is necessary.
Warranty
The Craftsman Chain Saw 358.352680 comes with a full one-year warranty. Within this period, if any defect in material or workmanship is found and the chainsaw has been maintained, lubricated, and tuned up according to the owner's manual, Sears will repair it free of charge. However, it's important to note that the warranty does not cover the bar, chain, spark plug, and air filter, as these are considered expendable parts that may wear out during normal use. If the chainsaw is used for commercial or rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, simply return the chainsaw to the nearest Sears Service Center in the United States. It's worth mentioning that this warranty provides specific legal rights, and additional rights may vary from state to state. The contact information for Sears, Roebuck and Co. is provided as follows: D1817 WA, Hoffman Estates, IL 60179.
Craftsman 358.352680 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 48
All Time: 472
