Shop the Holiday Gift Guide
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35218
Background
The Craftsman Chain Saw 358.352180 is a 2-cycle gasoline-powered tool designed for cutting wood. Manufactured by Poulan/WeedEater for Sears, the saw is equipped with a variety of controls and adjustments. These include an On/Stop Switch to halt the engine, a Throttle Trigger to regulate engine speed, and a Throttle Lockout that needs to be pressed before the throttle trigger can be activated, thus preventing accidental triggering.
The chain saw also features a Fast Idle Lock that holds the throttle trigger in the starting position, a Choke Knob for activating the choke to supply additional fuel to the engine during cold starts, and a Primer Bulb that circulates fuel to the carburetor for quicker starting. It has a Chain Tension feature that compensates for the normal stretching of a new chain during the first 30 minutes of operation. This tool is intended for wood cutting tasks and demands frequent checks on the chain tension for optimal performance.
Technical Specifications
  • Model Number: 358.352180
  • Product Type: Chain Saw
  • Engine: 2.2 cu. in./36cc 2-Cycle Gasoline
  • Bar Length: 18 in.
  • Controls and Adjustments: ON/STOP Switch, Throttle Trigger, Throttle Lockout, Fast Idle Lock, Choke Knob, Primer Bulb
  • Safety Features: Chain Brake, Spark Arrestor
  • Fuel Type: Gasoline
  • Oil Type: Bar & Chain Lube, 2-cycle engine oil
  • Additional Features: Chain Tension adjustment
  • Assembly: Comes fully assembled
  • Package Contents: Chain Saw (fully assembled), Bar tool, Chain, Carrying Case, Gloves, Gas Can, Bar & Chain Lube, 2-cycle engine oil
Warranty
The warranty for the Craftsman Chain Saw 358.352180 is a full one-year warranty. This warranty covers any defects in material or workmanship, and Sears will repair the chainsaw free of charge, as long as it has been maintained, lubricated, and tuned up according to the owner's manual. However, please note that the warranty excludes the bar, chain, spark plug, and air filter, as these are considered expendable parts and may wear out during normal use. If the chainsaw is used for commercial or rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, you can return the chainsaw to the nearest Sears service center in the United States. It is important to keep in mind that this warranty provides specific legal rights, and there may be additional rights that vary from state to state.
Craftsman 358.352180 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 41
All Time: 483
