No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.352181
Background
The Craftsman Chain Saw 358.352181 is a gasoline-powered tool designed for cutting wood. Manufactured by Poulan/WeedEater for Sears under the Craftsman brand, it has a 2.2 cu. in./36cc 2-Cycle engine and an 18-inch bar. The tool is equipped with multiple functional features including an On/Stop switch to control the engine, a throttle trigger to regulate engine speed, a throttle lockout to prevent accidental activation, and a fast idle lock to hold the throttle trigger in the starting position. The chain saw also features a choke knob that provides additional fuel to the engine during cold starting, and a primer bulb that circulates fuel to the carburetor for quicker starting. The chain tension can be adjusted as needed, as it is normal for a new chain to stretch during the first 30 minutes of operation.
The chain saw is designed to be used in a variety of settings, including commercial logging and residential tree maintenance. The tool is equipped with a chain brake (that must be ordered and installed separately for commercial logging) to comply with Federal OSHA Regulations. The device also has a spark arrestor that meets the requirements of California Codes 4442 and 4443. Regular maintenance tasks for this chain saw include adding lubricant to the sprocket hole after each use, cleaning the unit and labels with a damp cloth and mild detergent, and cleaning or replacing the air filter after a certain amount of operation time. The spark plug should be replaced annually to ensure optimal engine performance.
Technical Specifications
  • Model Number: 358.352181
  • Product: Craftsman Chain Saw 358.352181
  • Product Type: Chain Saw
  • Engine Type: 2.2 cu. in./36cc 2-Cycle Gasoline Engine
  • Bar Length: 18 in.
  • Features: Bar Oil Fill Cap, Housing, Fuel Mix Fill Cap, Fast Idle, Throttle, Choke, Chain Tension, Throttle Lockout, Fast Idle Lock, Primer Bulb, Bar Clamp Nuts
  • Switch: On/Stop Switch
  • Certification: Listed by Underwriters Laboratories, Inc. in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-I99t)
  • Spark Arrestor: Equipped with a temperature limiting muffler and spark arresting screen
  • Additional Accessories: Bar tool, Chain, Carrying Case, Gloves, Gas Can, Bar & Chain Lube, 2-cycle engine oil
Warranty
The Craftsman Chain Saw 358.352181 comes with a full one-year warranty. This warranty covers any defects in material or workmanship and is valid for one year from the date of purchase, as long as the chainsaw is maintained, lubricated, and tuned up according to the owner's manual. However, please note that the warranty does not cover the bar, chain, spark plug, and air filter, as these parts are considered expendable and may wear out during normal use. If the chainsaw is used for commercial or rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, you can return the chainsaw to the nearest Sears Service Center in the United States. It is important to keep in mind that this warranty provides specific legal rights, and you may have additional rights that vary from state to state.
Craftsman 358.352181 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 331
