2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.3516
Background
The Craftsman Chain Saw 358.351600 is a gasoline-powered chain saw, designed with a set of features aimed at providing a reliable and practical tool for cutting wood. Manufactured By POULAN/WEEDEATER for Sears under the Craftsman Brand, it is equipped with a 2.2 cu.in./36cc 2-Cycle engine and a 16 inch bar, making it suitable for a range of cutting tasks.
The chain saw includes several control and adjustment features such as an ON/STOP switch that halts the engine, a throttle trigger that controls engine speed, and a throttle lock-out that prevents accidental triggering. Other notable features include a choke/fast idle lever for cold starting and a primer bulb to facilitate quicker starting by circulating fuel to the carburetor. The chain saw also has a chain brake, designed to stop the chain in case of kickback. The chain brake can be activated both manually and automatically. Additionally, the device has a chain tension check and adjustment feature, acknowledging that it is normal for a new chain to stretch during the initial operation.
Technical Specifications
  • Model Number: 358.351600
  • Product Type: Chain Saw
  • Engine Type: 2.2 cu.in./36cc 2-Cycle Gasoline
  • Bar Length: 16 in
  • Safety Features: ON/STOP switch, Throttle Lock-Out
  • Additional Features: Choke/Fast Idle Lever, Primer Bulb, Chain Brake
  • Chain Direction: Forward
  • Handles: Front and Rear
  • Fill Caps: Bar oil fill cap, Fuel mix fill cap
  • Muffler: Equipped with spark arresting screen
  • Certifications: Listed by Underwriters Laboratories, Inc.
  • Emission Control Warranty Parts: Spark plug, ignition module, muffler, fuel tank
  • Compliance: EPA and/or California Emission Standards
Warranty
The Craftsman Chain Saw 358.351600 comes with a one-year full warranty. This warranty covers any defects in material or workmanship that may occur within one year from the date of purchase. If the product fails due to such defects, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement. However, please note that the warranty does not cover the bar, chain, spark plug, and air filter, as these are considered expendable parts that can wear out from normal use in less than one year. It is important to follow the operator's manual for proper use and maintenance of the product. For any questions regarding warranty rights and responsibilities, customers can contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be obtained at all Sears Service Centers, and any Sears-approved replacement parts used for warranty maintenance or repair on emission-related parts will be provided without charge if the part is under warranty.
Craftsman 358.351600 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 43
All Time: 508
