No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35156
Background
The Craftsman Chain Saw 358.351560 is a gas-powered chain saw produced by Poulan/WeedEater for Sears under the Craftsman brand. It features a 2.2 cubic inch/36cc 2-cycle engine and a 16-inch bar for cutting. The chain saw is designed with a range of controls and adjustments for operation, including an On/Stop switch to halt the engine, a throttle trigger to control engine speed, a throttle lockout mechanism, a fast idle lock, a choke knob for cold starting, and a primer bulb to circulate fuel for quicker starting. The chain saw also incorporates a chain tension feature, which allows for adjustments as the chain naturally stretches during use.
This chain saw can be used for various woodcutting tasks. The engine provides the necessary power to drive the 16-inch bar and chain, enabling the user to cut through different types of wood. Its controls and adjustments are strategically positioned to enhance user convenience during operation. For instance, the throttle trigger and lockout, choke knob, and fast idle lock are all within easy reach, allowing for straightforward operation and control of the chain saw's speed and performance. The primer bulb and chain tension feature further enhance the overall functionality of the product by ensuring quicker starting and maintaining optimum chain tension, respectively. All these features work together to provide an efficient and user-friendly woodcutting tool.
Technical Specifications
  • Model Number: 358.351560
  • Product Type: Chain Saw
  • Engine Type: 2.2 cu. in./36cc 2-Cycle Gasoline
  • Bar Size: 16in.
  • Chain Brake: Available
  • Spark Arrestor: Equipped
  • Certification: Listed by Underwriters Laboratories, Inc. in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-1991)
  • Assembly: Fully assembled
  • Fuel Filter: Included (may rattle in an empty fuel tank)
  • Carburetor: Precisely adjusted at factory
  • Included Items: Chain Saw (fully assembled), Bar tool, 2-cycle engine oil
Warranty
The warranty for the Craftsman Chain Saw model number 358.351560 is valid for a period of two years from the initial date of purchase. During this warranty period, certain repairs or replacements of parts will be performed at no charge to the owner at an approved SEARS servicing center. The warranty covers any warranted part that fails due to defects in materials or workmanship. However, it does not cover failures caused by abuse, neglect, improper maintenance, unapproved modifications, or the use of parts not made or approved by the original equipment manufacturer. To claim the warranty, the owner is responsible for presenting the lawn and garden equipment engine to an authorized SEARS repair center as soon as a problem exists. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days. For any questions regarding warranty rights and responsibilities, the owner can contact their nearest authorized service center or call SEARS at 1-800-473-7247.
Craftsman 358.351560 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 25
All Time: 337
