No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35134
Background
The Craftsman Chain Saw 358.351340 is a gasoline-powered chainsaw designed for cutting wood. It has a 2.0 cubic inch (33cc) 2-cycle engine and a 14-inch bar, which provides the length of cut. The chainsaw is powered by a gasoline fuel mix, which is stored in a fuel mix reservoir.
The chainsaw features several controls and adjustments for operation. It has an ON/STOP switch which is used to stop the engine. The engine speed is controlled by the throttle trigger. A throttle lockout feature must be pressed before the throttle trigger can be used, which prevents accidental operation. The chainsaw also includes a fast idle lock, which holds the throttle trigger in the starting position for easier start-up. The Choke Knob activates the choke to provide additional fuel to the engine during cold starting. The Primer Bulb circulates fuel to the carburetor to provide quicker starting. The chainsaw also has a chain tension feature, which needs frequent checking as it is normal for a new chain to stretch during the first 30 minutes of operation.
Technical Specifications
  • Engine: 2.0 cu.in./33cc 2-Cycle GASOLINE engine
  • Bar length: 14 in.
  • Model number: 358.351340
  • Spark arrestor: Equipped to meet California Codes 4442 and 4443
Warranty
The warranty period for the Craftsman Chain Saw 358.351340 is two years from the initial date of purchase. The warranty covers the repair or replacement of parts, including the carburetor and ignition system, as specified in the maintenance schedule. To claim the warranty, you need to present your lawn and garden equipment engine to an authorized SEARS service center or call SEARS at 1-800-473-7247. Warranty repairs should be completed within 30 days. SEARS is not liable for failures caused by abuse, neglect, improper maintenance, unapproved modifications, or the use of parts not made or approved by the original equipment manufacturer. If you have any questions about your warranty rights and responsibilities, you can contact your nearest authorized service center or call SEARS at 1-800-473-7247.
Craftsman 358.351340 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 39
All Time: 536
