3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.351081
Background
The Craftsman Chain Saw Model 358.351081 is a 2.4 cubic inch, 40cc, 2-cycle gasoline powered tool. It is designed for cutting tasks and is equipped with an 18-inch bar. The chain saw operates on a gas mix and has a dedicated fill cap for it. The chain direction of travel is indicated on the saw for user guidance.
The chain saw has various controls and adjustments for optimal use. It features a throttle lockout, which must be pressed before the throttle trigger can be squeezed, preventing accidental activation. Additionally, it includes a choke/fast idle lever, which when pulled out fully, sets the choke and fast idle speed for cold or refueled starting. The chain tension can be checked and adjusted frequently as new chains tend to stretch during the first 30 minutes of operation. The unit also comes equipped with a handguard and a chain catcher for user convenience.
Technical Specifications
- Model Number: 358.351081
- Product Type: Chain Saw
- Engine: 2.4 cu. in./40cc 2-Cycle gasoline engine
- Bar length: Models available with 16 in. or 18 in. guide bar
- Chain: Designed for use with 16 in. or 18 in. bar
- Carburetor: Equipped with adjustable idle speed screw ("T"), low speed mixture screw ("L"), and high speed mixture screw ("H")
- Fuel system: Requires mixed unleaded gasoline and 2-cycle engine oil
- Clutch: Automatic centrifugal clutch
- Chain tensioner: Tool provided for adjusting chain tension
- Chain catcher: Designed to catch chain if it breaks or derails
Warranty
The Craftsman Chain Saw 358.351081 comes with a full one-year warranty from the date of purchase. During this warranty period, Sears will repair any defect in material or workmanship free of charge, as long as the chainsaw is maintained, lubricated, and tuned-up as instructed in the owner's manual. The warranty does not cover the bar, chain, spark plug, and air filter, as these are considered expendable parts that may become worn during normal use. However, if the chainsaw is used for commercial or rental purposes, the warranty applies for only 30 days from the date of purchase. To claim the warranty service, the chainsaw needs to be returned to the nearest Sears service center in the United States. It is important to note that this warranty provides specific legal rights, and additional rights may vary from state to state.
