Shop the Holiday Gift Guide
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35104
Background
The Craftsman Chain Saw 358.351040 is a gasoline-powered tool typically used for cutting and trimming trees and branches. The product is equipped with a 2.1 cubic inches (34cc) 2-cycle air-cooled engine, capable of achieving a maximum of 12,600 RPM. It features a 14-inch (36 cm) guide bar and a low profile 3/8" pitch chrome cutters chain, designed to carry out cutting tasks efficiently.
The chain saw operates on a 40:1 fuel mix, with an integrated automatic oiler and a 6.0 oz oil tank to keep the chain lubricated during use. It is equipped with a solid-state ignition system, with a Champion CJ-7Y spark plug set at a gap of 0.025" (0.65mm) for the ignition process. The product incorporates a throttle lockout to prevent accidental squeezing of the throttle trigger. Additionally, a choke knob is included to provide additional fuel to the engine when starting a cold engine. The chain saw also has a primer bulb that circulates fuel to the carburetor. The on/stop switch is employed to stop the engine.
In terms of usage, the chain saw can be used for a variety of tasks ranging from tree felling and pruning to limbing and bucking. The device is designed for both casual and heavy-duty usage, making it suitable for both homeowners and professional landscapers. Regular maintenance of the chain saw, as outlined in the user manual, includes cleaning the unit and its labels, checking for damaged or worn parts, checking for loose fasteners and parts, checking chain sharpness, and guide bar maintenance.
Technical Specifications
  • Engine: 2.1 cubic inch (34cc) 2-cycle air cooled
  • Fuel Mix: 40:1 (3.2oz oil per gallon gas)
  • Bar Length: 14" (36cm)
  • Chain: Low profile 3/8" pitch with chrome cutters
  • Oiler: Automatic, 6.0 oz tank
  • Ignition: Solid state, fixed timing, 0.025" spark plug gap
  • Spark Plug: Champion CJ-7Y
  • Muffler: Spark arresting screen
  • Max Engine RPM: 12,600
Warranty
The Craftsman Chain Saw 358.351040 comes with a full one-year warranty. This warranty covers any defects in material or workmanship for one year from the date of purchase, as long as the chain saw is maintained, lubricated, and tuned up according to the owner's manual. Sears will repair any eligible defects free of charge during this warranty period. However, please note that the warranty excludes the bar, chain, spark plug, and air filter, as these are considered expendable parts that may wear out during normal use. If you need to claim the warranty, you can do so by returning the chain saw to the nearest Sears Service Center in the United States. It is important to follow the instructions in the owner's manual for proper maintenance and care of your chain saw to ensure the warranty remains valid.
Craftsman 358.351040 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 41
All Time: 483
