No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.35048
Background
The Craftsman Chain Saw 358.350480 is a gasoline-powered tool designed for cutting wood. Manufactured by Poulan/Weedeater for Sears under the Craftsman brand, it features a 2.6 cubic inch/42cc 2-cycle engine and an 18-inch bar. This chain saw is equipped with several controls and adjustments, such as a throttle trigger that controls engine speed, a choke/fast idle lever for cold or refueled starting, and a primer bulb that circulates fuel to the carburetor for quicker starting.
It also includes an ON/STOP switch to halt the engine, as well as a chain brake designed to stop the chain in the event of kickback. The chain tension can be checked and adjusted as necessary, as it is normal for new chains to stretch during initial use. The unit can be filled with a fuel mixture for operation, while the bar sprocket hole should be lubricated after each use. The device's air filter can be cleaned and replaced for optimal engine performance, and the spark arresting screen on the muffler should be cleaned regularly to prevent fire hazards and maintain engine performance.
Warranty
The Craftsman Chain Saw 358.350480 comes with a full one-year warranty. This warranty covers any defects in material or workmanship and is applicable as long as the chainsaw is maintained, lubricated, and tuned up according to the instruction manual. However, it does not cover the bar, chain, spark plug, and air filter, as these are considered expendable parts that may become worn during normal use. If the chainsaw is used for commercial or rental purposes, the warranty applies for a period of 30 days from the date of purchase. To claim the warranty, the chainsaw must be returned to the nearest Sears store or service center in the United States. It is important to note that this warranty provides specific legal rights and additional rights may vary from state to state.
Craftsman 358.350480 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 49
All Time: 646
