Shop the Holiday Gift Guide
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.3502
Background
The Craftsman Chain Saw 358.350200, manufactured by Poulan/Weedeater for Sears, is a 2-cycle gasoline-powered tool designed for cutting wood. With a 2.8 cu.in./46cc engine and a 20-inch bar, it offers a balance of power and control for regular use. The chain saw is equipped with several controls and adjustments including an ON/STOP switch to control the engine, a throttle trigger to regulate engine speed, and a throttle lock-out to prevent accidental squeezing of the trigger.
The chain saw also incorporates a choke/fast idle lever for cold or refueled starting and a chain brake, which is designed to stop the chain in the event of kickback. The chain tension can be adjusted for optimal performance, and the device features a chain oiler for continuous lubrication to the chain and guide bar. The Craftsman Chain Saw 358.350200 is certified to operate on unleaded gasoline mixed with a good quality 2-cycle air-cooled engine oil, with an oil to gasoline ratio of 40:1.
Technical Specifications
  • Model Number: 358.350200
  • Product Type: Chain Saw
  • Engine: 2.8 cu.in./46cc 2-Cycle GASOLINE
  • Bar Length: 20 In.
Warranty
The warranty for the Craftsman Chain Saw 358.350200 is valid for a period of two years from the initial date of purchase. The warranty covers the repair or replacement of any warranted part at no charge to the owner at an approved Sears servicing center. It is important for the owner to perform the required maintenance listed in the instruction manual and retain all receipts for maintenance. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days. If there is a need to claim the warranty, the owner should present the equipment to a Sears authorized repair center. For any questions regarding warranty rights and responsibilities, the owner can contact their nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.350200 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 477
