Shop the Holiday Gift Guide
2 Diagrams
Documents
Models
919.16731, 919.167310
Background
The Craftsman Air Compressor model 919.167310 is a portable, single-stage air compressor that is manufactured by Ingersoll Rand for Sears under the Craftsman brand. This air compressor is equipped with a permanently lubricated motor, which eliminates the need for oil maintenance. The compressor is designed to be portable, making it suitable for various tasks that require mobility.
The air compressor is equipped with a pressure switch, safety valve, outlet pressure gauge, tank pressure gauge, and regulator. The pressure switch automatically starts and stops the motor based on the air tank pressure. The safety valve protects against high pressure. The outlet pressure gauge indicates the air pressure available at the outlet side of the regulator, while the tank pressure gauge shows the reserve air pressure in the tank. The regulator controls the air pressure shown on the outlet pressure gauge. The air compressor also features a cooling system and a check valve for efficient operation. The compressor is capable of powering various accessories, including a caulk gun, engine cleaner, tire air chuck, and various carpentry tools.
Technical Specifications
  • Model Number: 919.167310
  • Product Type: Air Compressor
  • Lubrication: Permanently Lubricated
  • Stages: Single Stage
  • Tank Size: 30 gallon
  • Power: 6HP - Horse Power
  • Portability: Portable
  • Air Delivery Unit: 6.4cfm @ 90psi - Cubic feet per minute (CFM), Standard cubic feet per minute (SCFM)
  • Pressure Measurement Unit: 150psi max - Pounds per square inch gauge (PSIG)
  • Safety Standards: American Society of Mechanical Engineers (ASME), Underwriters Laboratories Standards
  • Cut-In Pressure: variable - Factory set low pressure at which the motor automatically restarts
  • Cut-Out Pressure: 150psi - Factory set high pressure at which the motor automatically shuts off
  • Capable of Powering: Various Accessories including Caulk Gun, In Line Filter, Engine Cleaner, Tire Air Chuck, Sand Blaster, Quick Connector Sets, Carpentry Tools, Finishing Nailer / Stapler, Air Pressure Regulators, Construction Nailer/Stapler, Oil Fog Lubricators, Impact Wrenches, Specialty Tools, Spray Painting Tools, Material Shaping Tools, Finishing/Sanding Tools
  • Air Hose Sizes: 1/4", 3/8" or 1/2" I.D. in various lengths
  • Contents of Carton: 1 Air Compressor, 2 Wheels, 2 Shoulder Bolts (3/8-16), 2 Hex Nuts (3/8-16), 2 Rubber Bumpers, 2 Screws (1/4-20 x .75)
  • Assembly Tools Required: 9/16" socket or open end wrench, 1/2" socket or open end wrench
Motor Bearing Replacement -- https://www.youtube.com/watch?v=lgYrRsSX...
Warranty
The Craftsman Air Compressor model 919.167310 comes with a full one year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails due to either of these reasons within one year from the date of purchase, it can be returned to the nearest Sears Repair Center throughout the United States, and Sears will repair it free of charge. If the air compressor was purchased from Orchard Supply Hardware, it can be returned to the nearest Orchard Store for a free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty duration is shorter and will only apply for ninety days from the date of purchase.
This warranty provides specific legal rights, and there may be other rights available that vary from state to state.
Craftsman 919.167310 Owners Manual
Craftsman 919.167310 Permanently Lubricated Single Stage Portable Air Compressor Operator's Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 86
All Time: 1,106
