2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.166442
Background
The Craftsman Air Compressor 919.166442 is a durable air compressor manufactured by Ingersoll Rand for Sears under the Craftsman brand. It is designed for a variety of uses, including powering air tools, inflating tires, and other tasks requiring pressurized air. The product features a 15-gallon tank capacity and operates on a single-phase 120V/60HZ/1 PH power supply. It has a running horsepower of 1.5 and a stroke of 1.25". The air compressor has a minimum branch circuit requirement of 15 amps and a fuse type of time delay. It has an approximate cut-in of 120 and cut-out of 150. The air compressor delivers 4.9 SCFM at 40 psig and 3.5 SCFM at 90 psig. It is equipped with a permanently lubricated tank mounted air compressor, a pressure switch, a safety valve, an outlet pressure gauge, a tank pressure gauge, a regulator, and a drain valve. It also features a cooling system for efficient operation.
Technical Specifications
  • Model Number: 919.166442
  • Product Type: Air Compressor
  • Running Horsepower (HP): 1.5
  • Bore: 1.875"
  • Stroke: 1.25"
  • Voltage-Single Phase: 120V/60HZ/1 PH
  • Minimum Branch Circuit Requirement: 15 amps
  • Fuse Type: Time Delay
  • Air Tank Capacity: 15
  • Approximate Cut-In: 120
  • Approximate Cut-out: 150
  • SCFM @ 40 psig: 4.9
  • SCFM @ 90 psig: 3.5
Warranty
The Craftsman Air Compressor 919.166442 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails due to these issues within one year from the date of purchase, Sears will either repair or replace it free of charge. To claim the warranty, you can contact your nearest Sears Service Center at 1-800-4-MY-HOME to arrange for repair, or return the air compressor to the place of purchase for replacement. Please note, if the air compressor is used for commercial or rental purposes, the warranty applies for only ninety days from the date of purchase.
Craftsman 919.166442 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 60
All Time: 488
