Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Corsair K60 Pro TKL RGB was released September 13th, 2022, and is a mechanical gaming keyboard with a compact style, optimized performance, and an aluminum frame. The keyboard is made to prioritize input and offers 8,000Hz polling, a durable design, and smooth linear travel for gaming performance. Along with features through iCUE to customize the full appearance of the keyboard via lighting controls. Its tenkeyless (TKL) layout removes the number pad, allowing for more desk space and mouse movement. The keyboard is equipped with Corsair’s OPX optical-mechanical switches. The K60 Pro TKL RGB is designed to balance performance, customization, and durability for both casual and competitive gamers.
Identification
The Corsair K60 Pro TKL RGB is a compact tenkeyless (TKL) keyboard, which measures at 14.2 x 5.36 x 1.42 inches. The keyboard has an 87-key layout, removing the keypad, with an aluminum frame. Along with the frame, the Corsair K60 Pro TKL RGB utilizes a 1.82m USB 3.0 Type-A connection cable.
Technical Specifications
  • Wired Keyboard with USB 3.0 or 3.1 Type-A
  • 0.96kg Weight
  • Tenkeyless
  • 87 Keys
  • Adjustable Height
  • CORSAIR OPX Optical-Mechanical Switches
  • Full Key (NKRO) with 100% Anti-Ghosting
  • iCUE Supported
  • Report Rate up to 8,000Hz
Additional Information
Corsair K60 Pro TKL RGB Home page
Corsair K60 RGB Pro Review: Back to Basics
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 39
All Time: 304
