Documents
Chevrolet HHR Technical Specs
Engine and Performance
  • 2.2L Ecotec I4 (Base): Produced 143 hp to 155 hp depending on the year; a reliable, high-volume engine found in many GM compacts.
  • 2.4L Ecotec I4 (LE5): Offered as an upgrade on the LT trim, producing 172 hp to 175 hp and 167 lb-ft of torque.
  • 2.0L Turbocharged Ecotec (SS Model): The high-performance "Super Sport" variant delivered a significant jump to 260 hp and 260 lb-ft of torque, capable of 0-60 mph in approximately 6.3 seconds.
Drivetrain and Transmission
  • Transmission Options: A 5-speed manual (Getrag) or a 4-speed automatic (4T45-E).
  • SS Performance Tech: The SS model featured a unique "No-Lift Shift" program in the manual version and an optional Limited Slip Differential (LSD).
  • Brakes: Base models utilized front discs and rear drums, while the SS model was upgraded to 4-wheel discs with optional Brembo front calipers.
Chassis and Versatility
  • Suspension: Independent MacPherson struts in the front and a semi-independent torsion beam in the rear. The SS trim featured a "FE5" performance-tuned suspension.
  • Cargo Capacity: The HHR was highly praised for its flat-folding front passenger seat and "Easy-Clean" plastic cargo floor, providing up to 57.7 cubic feet of storage space.
  • Panel Van Variant: A unique "Panel" version was available for commercial use, featuring windowless side panels and rear "cargo doors" without exterior handles, operated via a dashboard release or key fob.
Dimensions
  • Wheelbase: 103.5 inches (2,629 mm).
  • Length: 176.2 inches (4,475 mm).
  • Curb Weight: Approximately 3,155 lbs for base models.
oldturkey03
863,989 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
72 Members
3,060 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 91
All Time: 347
