Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Chef's Counter Rice Cooker
RC-3
There is a mechanical lever to switch between warm and cook settings. There are two white LED lights with orange and red coverings to indicate which setting is being used.
A DF184S Thermal Cutoff Fuse is in place to protect the device by disconnecting the circuit in the event of a heating element malfunction.
Identification
  • Labeled with Chef's Counter on the front
  • 3 cup rice cooker
  • Warm and cook settings on the front with a mechanical lever
  • Two small handles located on the sides
  • Removable lid and rice bowl
  • The model number can be found on a sticker located at the bottom of the device
Specifications
Warm Setting:
120V
0.24 amps
29.8 watts
temp: 150 degrees Fahrenheit
Cook Setting:
120V
2.42 amps
290 watts
temp: 212 degrees Fahrenheit
Dimensions:
Height: 16 cm
Width: 18.5 cm
Radius: 9.25 cm
Cord Length: 1 m
Additional Information
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 57
All Time: 655
