Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background:
The CE-300 was initially marketed primarily in Japan and the United States, quickly becoming a favorite for its warm, analog tone. Though discontinued later in the 1980s, it remains valued by vintage gear collectors and musicians interested in analog effects, as digital effects eventually became more standard. While it is generally durable, aging units sometimes exhibit issues in power-related components, typical of vintage equipment. Nonetheless, the CE-300 is well regarded for its reliable build and remains sought after in the used market for its unique sound quality.
The Boss CE-300 Super Chorus was released in 1984 to add chorus effects to virtually any electronic instrument – except for microphones - without the use of pedals. Boss originally released a device that operated similarly without the option to mount in a rack – the “Stereo Chorus”. The CE-300 also allows a pedal to be used at the same time if desired.
 The CE-300 can change the phases as well as the effects. Output A produces a “positive” phase, Output B produces a “negative” phase. Both outputs will produce sound with the chorus effect. If the chorus effect is not desired, the device comes with an Effect ON/OFF switch which will not mute the direct sound, just the effect. It also comes with a Direct Mute switch which will mute the direct sound, but not the chorus effect.
Source
Identification:
The device can be identified by the writing on the right side. The device has a blue “SUPER CHORUS” towards the middle, and white “BOSS CE-300" on the right-hand side. The device comes with mounts on both left and right sides for rack mounting.
Technical Specifications:
  • Input Level (Rated): -20dBm
  • Input Level (Maximum): +12dBm
  • Input Impedance: 1MΩ
  • Output Level (Rated): -20dBm
  • Output Level (Maximum): +12dBm
  • Output Load Impedance: More than 10k Ω
  • Gain: 0dB, 0.775 V RMS
  • Controls: Input Level, Modulation Rate, Modulation Depth, Chorus Tone, Chorus Level
  • Switches: Effect, Direct mute, Power
  • Indicators: Effect, Input Level, Direct Mute, Power
  • Jacks: Input x 2, Output A(A+B) x 2, Output B x 2, Effect Remote (ON/ OFF) x 1
  • Power: 117/220/240V, AC 50/60Hz
  • Power consumption: 5W
  • Dimensions: 482x47x246 mm, 19" x  1⅞" x 9¹¹⁄₁₆" (w x h x l)
  • Weight: 3.1kg, 6lb 14oz
  • Options: Foot Switch FS-1
Source
Additional Information:
Author
with
Rashed
285 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 42
All Time: 1,079
