No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
1711A
Background
The Bosch Angle Grinder 1711AD is a handheld tool primarily used for cutting, grinding, and polishing. Designed by Bosch, this tool is equipped with an 1850-watt motor, which allows it to attain a no-load speed of 8,500 RPM. The tool itself is 12.4 inches long and has a weight of 5.7 lbs.
The grinder's features include a spindle lock for swift wheel changes and it can accommodate 7/8 inch arbor wheels up to 7 inches in diameter. Further, it is designed for two-hand operation, which can lead to enhanced control during use. The device is operated via a slide switch on the top of its handle. Lastly, the spindle lock button ensures quick wheel changes by securely locking the spindle to loosen the nut.
Technical Specifications
  • Model Number: 1711AD
  • Product Type: Angle Grinder
  • Motor Power: 1850 watt
  • No Load Speed: 8,500 RPM
  • Weight: 5.7 lbs
  • Length: 12.4 inches
  • Spindle Lock: Yes, for quick and easy wheel changes
  • Arbor Size: 7/8 inch
  • Compatible Wheel Diameter: Up to 7 inches
  • Operation: Slide switch, side handle for two hand operation
  • Included Accessory: Keyless guard for fast adjustments
Warranty
The Bosch Angle Grinder 1711AD comes with a warranty that lasts for one year. This warranty covers defects in materials and workmanship, implying that if any part of the grinder is found to be defective due to the materials used or the way it was made, Bosch will repair or replace the defective grinder. To successfully claim this warranty, it would be essential to provide proof of the defect, and usually, the product must be returned to the manufacturer or authorized service center. It's recommended to check the user manual or contact Bosch's customer service for specific instructions on how to claim the warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 36
All Time: 369
