2 Diagrams
Documents
Models
1380SLIM
Background
The Bosch 1380SLIM angle grinder is a power tool designed for a range of applications, including grinding, cutting, and polishing. It features a 7.5 amp, single-speed motor that delivers 11,000 RPM, and operates on a 120V voltage. The wheel diameter of the grinder is 4-1/2 inches, and it has a spindle thread of 5/8 inches. The tool's overall length is 11 inches and it weighs 4.2 lbs. It is equipped with a 2-position auxiliary handle for enhanced user comfort and control, and a slide switch with lock-on and lock-off settings for ease of use.
The 1380SLIM angle grinder is designed to be durable, reliable, and easy to maintain. It incorporates several protective features, such as sealed switches to keep debris out, epoxy-coated field windings to protect against abrasive dust and metal debris, and directed airflow to divert dust away from the switch and vital components. Additionally, the grinder has service minder brushes that stop the tool when preventative maintenance is required, spindle lock for quick wheel changes, removable brush covers for easy brush replacements, and a reinforced wheel guard.
Technical Specifications
  • Amperage: 7.5
  • Horsepower: 1
  • RPM: 11,000
  • Spindle Thread: 5/8 in. - 11
  • Switch Settings: Lock-On / Lock-Off
  • Switch Type: Slide
  • Voltage: 120V
  • Wheel Diameter: 4-1/2 in.
  • Length: 11 in.
  • Weight: 4.2 lbs.
Bosch 1380SLIM Manual
Grinders and Metalworking Tools and Accessories
Bosch Model 1380SLIM Small Angle Grinder Safety Recall Notice (Date Codes 502–511)
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 193
All Time: 3,239
